are 05-06 axles stronger than 04 axles?
The 04 axles have a smaller outer splined end and a really odd ball cv joint with smaller internals that the inner cv joint.
The 04 shafts will have a part # AB2704 92067184
The 04 outer shaft dia is right around 1.1" and the 05-06 dia is 1.25"
The 05-06 half shafts will interchange with the 04's, they have the same bolt pattern and are the same length. They bolt right in.
