10 Second Club - Hit 10s finally
View Full Version : Hit 10s finally
1fastTransAm
10-23-2010, 09:49 PM
http://i57.photobucket.com/albums/g230/1fasttransam/timeslip.jpg
Admin can I get my 12sec club changed now? LOL
Was in a
01z28
with
383
72mm
currie 9in with 4.11s
6speed car.
Gears are getting changed soon
1fastTransAm
10-23-2010, 11:50 PM
Engine
383 w/Stock Block 9:1 compression
Callies Compstar 4in crank
Compstar Rods
Weisco dished pistons
Stock 241 heads
Hardened pushrods
ARP Head studs
ARP Rod bolts
LS6 Intake
LS6 Cam
Griffin radiator
GM Performance valve covers
Stock rebuilt t56
Spec stage 3+ clutch and billet flywheel
Turbo stuff
Borg Warner S472 Front mounted turbo @16lbs
5in downpipe
Precision 46mm wastegate
Tial 50mm BOV
eBay intercooler with 3in piping
Fuel system
16 gallon fuel cell
Dual 255 pumps
Summit fuel rails
Aeromotive Fuel pressure regulator
60# injectors
Suspension
QA1 adjustable shocks front and rear
Adjustable springs on rear
Currie 9"in rear w/411 gears
No ABS or E-brake provisions on rear end
Has LT1 rear brake calipers (they are much smaller, no grinding required)
PA Racing tubular k-member
S&W mild steel 12pt roll cage
GM Performance slotted/drilled rotors on front
