Gears & Axles - F Body 10 bolt is it worth it
View Full Version : F Body 10 bolt is it worth it
NHRA4MULA
10-24-2010, 11:01 AM
Can you build a bullet proof 10 bolt with axles, posi unit and gears or is it just not worth it ???? The 10 bolt is way lighter than any thing else out there right....and do all of the 10 bolts out there sing when your going down the road because that will just kill it for me I just dont want to here the noise..
SweeTbone
10-24-2010, 11:21 AM
Not even worth the effort and cost. Go for a 9", especially being an M6. As for noise, being a "weekend warrior" or street/strip car, performance parts are going to have more noise/harsh ride than stock components. Just part of the trade off of going faster.
BlkBird2000
10-24-2010, 03:05 PM
Buy a fabricated Moser 9 inch or a midwest chassis fab rear end. Both are good choices and both come with a custom torque arm. They also weigh about the same, or closest to a 10 bolt than any other rear end.
NHRA4MULA
10-24-2010, 04:22 PM
thats what I was planning I just thought I'd ask
rabbit320
10-28-2010, 05:06 PM
i forget which but one site said there moser 12 bolt weighed as much as the 10 stocker
Bob@BruteSpeed
10-30-2010, 06:00 AM
My Moser 12 bolt that I use to have was exactly 47 lbs heavier than the 10 bolt was. Bob
http://www.exoticperformanceplus.com/images/projectCarImages/BOB10.jpg
SS4Luck
10-30-2010, 06:04 AM
any sort of gear, especially in a 10 bolt will whine a bit, yuoll get over it, just get the exhaust louder or turn the radio up. Its one of those things where you pay to play. My 4.56s whine as loud as my 10 bolt did when it was on the way out but everytime i hit the loud pedal it reminds my why i love them
RedRallyeZ
10-30-2010, 09:48 AM
my 3.73's in the 10 bolt sound stock. PERFECTLY quiet. not saying its normal at all, but its not a given that gears will always whine. I did have mine professionsally installed by a shop around here, so i paid to have it like that, but for me it was worth it.
NHRA4MULA
10-30-2010, 11:03 AM
I didnt think any company came up with anything really worth putting in the 10bolt.. i just thought i ask.. when mine goes I just put in a 12 bolt and I think that will be about 2 hours after the cars running and tuned ...because I know how I am to stupid to lift
Carl at CRP
10-30-2010, 11:54 AM
Yes the 10-bolt leaves a lot to be desired.
The 12-bolt is not to be sneered at though, it is capable of taking a car deep in the 10 sec et's and quicker!
A 9" is capable of geez who knows how quick, is it necessary? Only if You are planning on going very fast. Is it desirable? Yes? But more for bragging rights and re-sale value than necessity.
A 12-bolt has the pinion 1.50" below the center line of the ring gear compared to 2.25" on the 9", which is why the 12-bolt is rated by Strange Eng. as 3% more efficient than a 9".
Hope this helps.
Carl
mjcotroneo
10-31-2010, 05:56 AM
these 10 bolts will never be bullet proof. if you are capable to doing work yourself and have the parts then why not just build it just for kicks. thats what im doing. i have a locker, moser axles and a housing with welded axle tubes. all of that i got for free. now im gonna get a ta cover for it and put braces on it and of course the braces and rebuild kit with shims, bearings, seals, and crush sleeve will be the most expensive part and still cheaper but it should hold up for some dr launches lol
Bob@BruteSpeed
10-31-2010, 07:11 AM
Take a look at the info I put together at this link as it may help you out.
https://www.brutespeed.com/rear_end_information.htm Bob
71novaguy
10-31-2010, 08:33 AM
agreed. I wouldnt expect them to whine either. Sure it can happen, but not always.
Hope this helps.
Carl
What the loss in efficiency between a 10 bolt and a 12 bolt? I though there were stories of guys going 10's with the 10 bolt? May be a bit dangerous, but I though it had been done.
I'm in the mind set of the OP tho. It would be nice to have a built 10 bolt that can handle a 10 second car if it can keep the efficiency.
01ssreda4
10-31-2010, 08:35 AM
10 bolts are crap for an M6 PERIOD. You must purchase a rear end to make a 6 speed car quick.
Absolutely it can be done.....in an auto. I have seen 100k rear ends take awful beatings in autos, even raising the front tires by being sprayed out of the hole. By beatings though I did not mean wheel hop or things of that nature.
mjcotroneo
10-31-2010, 04:41 PM
yup^^^^ donnies 3rd gen went 9.80's on a stock 10bolt with 2:73's and 16" drs.it was a 383 w/ 300 pill and proform 950 hooked to a th350 and a steel driveshaft.
Ls1nutZ28
05-13-2013, 10:02 AM
[QUOTE=01ssreda4;14060782]10 bolts are crap for an M6 PERIOD. You must purchase a rear end to make a 6 speed car quick.
I have a friend running a m6. His car launches at 5600 rpms slipping the clutch on billet street lites, hooiser slicks on a stock 10 bolt with a TA cover, pinion spacer and shim kit on stock axles and with just a cam swap it ran a 7.6 in the 1/8th. I wouldnt say its impossible. Yes I realize a cam swap car and cut outs isn't a huge power maker but as we all know the stock 10 bolts can bust with just a stock Ls1. So I am highly impressed with how his built 10 bolt is holding up. Im not saying a 9" is not worth the money but if you are on a budget, a 10 bolt imo can be built up right to last some hard launches. I will be doing the same thing to my 10 bolt. For $600 price includes axles is WAY cheaper then $2500+ for a 9". If you are able to pay the price for a 9" then I would say go for it. I have nothing bad to say about the 9" but I am simply saying for a cheaper route you can skate by on a built 10 bolt for awhile. Ws6Store.com is a perfect place to buy the build kit and set of gears. I will be running a perfect launch ta cover, arp bolts, 4.11 gears, pinion spacer and shim kit with Moser axles. My z28 is roughly 400-420 rwhp H/C/I launching off Nitto NT05R drag radials M6 car with Monster Stage 2 LSX clutch and tick master cylinder. Hopefully the 10 bolt holds up as well as my buddies has.
BrntWS6
05-13-2013, 10:12 AM
Isn't a 12 bolt and 9" about the same price once you factor in the torque arm? Might as well get the 9".
