Small Block & Big Block Chevy Specific - Getting closer
ROBS SS
10-24-2010, 10:52 PM
update on the ride.....
got the brake lines finished up and the motor in ....time to have some headers made in the next week or so and finish the wiring....here is a few pics enjoy
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0465.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0471.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0478.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0486.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0488.jpg
QwkTrip
11-10-2010, 06:20 PM
Nice. Are you not going to use a conventional distributor?
ROBS SS
11-10-2010, 10:01 PM
using a crank trigger set-up
tektrans
11-11-2010, 06:59 AM
man that's nice. Who's mid plate is that? What block did you use? How many cubes?
I just bought a 632 (Merlin III block), gonna stuff it in my TA.
I'm going with a front belt and distr. drive set up.
ROBS SS
11-11-2010, 05:25 PM
its a madman front/mid plate mid plate has been trimmed up to fit, its a dart little M block and its only 393ci
ROBS SS
12-16-2010, 06:02 PM
update....got the headers done...got some mufflers on order , then off for coating ,now time to wire it up! :chug:
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0917.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0918-1.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0921.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_0924.jpg
cambirdracing
12-17-2010, 06:23 AM
Your carb is on sideways, haha.
Looks nice. Makes me jealous.
BACKAGAIN
12-17-2010, 10:13 AM
That looks sick!!
ROBS SS
12-22-2010, 07:12 PM
thanks guys, I hope to have it running the first of the year so i can do some testing
ZONES89RS
12-22-2010, 07:56 PM
What made you go with so little cubes?
ROBS SS
12-23-2010, 04:27 PM
there is weight breaks in many classes out here, and sb2's dont really need big ci's to make big power ;)
ROBS SS
02-22-2011, 10:38 PM
well getting a few things done...got the alt and vaccum pump mouthed along with the overflow tanks and fan....gonna weld some -16 AN fittitings on the radiator and get all the lines made....looks like after this weekend will just need to be wired...heres a few pics
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1087.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1099.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1097.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1092.jpg
ROBS SS
03-08-2011, 06:05 PM
get to start on the wiring this next week, just got the headers back from getting coated.....they look shinny!
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1135.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1132.jpg
Oldsmobility85
03-08-2011, 08:14 PM
Looks great. So do those beadlocks. What kind of driveline setup are you using and how much converter?
87silverbullet
03-08-2011, 08:17 PM
With your car being black and putting in a sb2 smallblock it reminds me of one of the old Pinks shows that had the same setup. That guy gave a big block car something like 8 cars and still hunted him down!
Good luck with the build. That is going to be one nasty ride when you are done!
ROBS SS
03-08-2011, 08:34 PM
im running a glide....the converter is a neal chance 8" 6500 stall
Oldsmobility85
03-08-2011, 10:14 PM
Bolt together style converter? 9" out back I assume? Should cut in the mid 1.2x 60ft range I would imagine.
That millers race engines sb2 camaro was fast as hell.
ROBS SS
03-08-2011, 11:13 PM
no bolt together...its ther regular converter....and the car has a strang 12-bolt in it (12-bolt was in the car when i got it)
ROBS SS
03-09-2011, 05:14 PM
just got the last of the lines done, went ahead and put AN fittings on the radiator and got a new water neck with a AN fitting ...painless wiring harness on order hope to get started on it this weekend...:chug:
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1139.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1141.jpg
warp10
03-09-2011, 09:34 PM
I'm in love. :D
Oldsmobility85
03-09-2011, 10:24 PM
Damn im wrong all the way around. Lol. Man those Rad hoses look awesome but that price tag for big an fittings upsets me big time. No need for all that.
Beaflag VonRathburg
03-09-2011, 11:11 PM
^ When you have an SB2.2 engine I'm guessing those little fittings pale in comparison to the rest of the combo.
ROBS SS
03-09-2011, 11:20 PM
wasnt bad at all...think i have $125 in top and bottom hoses and fittings
ROBS SS
03-09-2011, 11:27 PM
and on a side note...look closely at the alternator belt...the lower hose go's through the middle of it, and im not taking a chance of that belt nicking that lower hose on a pass down the track...could be badd news....look at a few of the older pics in the thread...had a regular water neck on and radiator had regular hose ends still...planed on rubber hoses till i got eveything together....so if im gonna do the bottom hose might as well do the top....building one of these...is a 1-off deal buy parts as ya go...:chug:
ROBS SS
03-09-2011, 11:43 PM
heres a few pics to show how close ..and im not even sure a regular rubber hose would fit
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1124.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/IMG_1125.jpg
merim123
03-10-2011, 09:01 AM
looks great. the ground clearance on those headers is awesome. are they custom btw, didn't see that in the thread?
ROBS SS
03-10-2011, 03:17 PM
the headers were custom...by greg @ R.E.F. unlimited...cool guy....comes to your door and does the headers in about 8hrs...1-day
Oldsmobility85
03-11-2011, 01:36 AM
Damn curb side service! What did that run you? I was gonna buy a set of 12AN bungs and swivel 90° hose ends for my evac setup but was pissed about the cheaper red horse brand being 25 bucks per fitting and 20 each for weld in bungs and almost 10 bucks a foot for the hose. I could afford it but just couldnt talk myself into it. Lol. Yours looks amazing though.
ROBS SS
03-13-2011, 03:10 PM
the headers were just over $1400 with the merge colletors
Wicked94Z
03-26-2011, 08:16 PM
bump for wiring pics :D lol
Oldsmobility85
03-26-2011, 11:26 PM
Yeah rob we testing this thing yet?
ROBS SS
05-27-2011, 02:49 PM
not yet...lol working on the wiring now...should be running next week some time....lots of little things to button up on this thing
ROBS SS
06-07-2011, 11:04 PM
well got her running today.......waiting on the drive shaft should be in tomorrow...here is a few pics will try and post a vid in the next day or 2
http://i854.photobucket.com/albums/ab107/camaroracer2/sb2camaro1.jpg
http://i854.photobucket.com/albums/ab107/camaroracer2/sb2camaro.jpg
