Iac
Iac
New install
5.3, 700R4, Jeep
motor is from a 2004, throttle body is from a 2001, performance tune, and harness from Jim's performance, got a few kinks worked out
It has idled super high 1800-2100 rpms since the first start up, throws a IAC code that reads, senses high idle
I have swapped IAC from jeep to running tahoe, both IAC's perform great on the tahoe
I have continuity through all 4 IAC wires from the computer to the harness plug, so wiring is all good
I can manually manipulate the IAC, pull it out, push it in, and I guess the computer will not change it
computer came out of a running, driving vehicle, what else am i looking for?
5.3, 700R4, Jeep
Moderator
Are you the PCM is right for the job? Some PCMs have
the IAC driver circuitry missing.
Measure each IAC phase to GND with a DMM with the
engine running, poke through the insulation with a
needle & clip-lead. If you see less than 100mV on all
of them, the PCM isn't trying.
Ran into this on an '04 Silverado AWD doing a big cable
TB swap, had to go to an '03 Savana PCM.
Can it be added to a pcm that doesnt have it, by a tune?
And is everything good with your fuel system? If the injectors are leaking or pulse width is too high the computer will read a rich condition increasing air in manifold and in the end raising idle.
PCM's with IAC drivers Green is good Red is not
SERV. NO.- HWD NO. -
12576106 - 12570558 - 2003 G-VAN, LM7, IAC DRIVERS INSTALLED. ALSO C-TRUCK LM7
12582605 - 12580786 - 2003 C-MPV, L59
12586242 - 12583660 - 2004 C/K-TRUCK, LM7
12586243 - 12583659 - 2004 GTO LS1, IAC DRIVERS INSTALLED
12589463 - 12589162 - 2005 C/K-TRUCK/MPV, LM7, LQ4
12589462 - 12589161 - 2005 G-VAN, LQ4, IAC DRIVERS INSTALLED
12589463 - 12589162 - 2006 C-PICKUP, LM7
12602802 - 12589162 - 2006 C-PICKUP, L59
12602801 - 12589161 - 2006 - 2007 Express, Drive by Wire, (has IAC drivers)
not sure if the injectors are leaking, motor didnt have but 38,000 miles on it from the wrecked vehicle
how do you check pulse width?
I had a lean and rich code at first, but o2 sensors were backwards
I don't really see a injectors with 38k mi. on them leaking. You could use a DSO, such as a picoscope, but doubt you would want to pay full price for one.
New computer didnt change a thing, still high idle
I put the old computer back in, pulled the IAC out, manually pulled it completely out where the IAC seperated the plunger from the spring, put it back together enough to where it should be at idle, reinstalled the IAC, and it sat there and idled perfect
The computer is not controlling the IAC
1999 to 2002 all PCM's support IAC
2003+
SERV. NO. - HWD NO.
12576106 - 12570558 - 2003 G-VAN, LM7, IAC DRIVERS. C1500 LM7
2004
Silverado PCM, DOES NOT WORK with cable throttle:
Serv. No. 12586242
Hwd. No. 12593660
2005 & 2006
Serv. No. 12589463
Hwd. No. 12589162
2003+
SERV. NO. - HWD NO.
2004
Serv. No. 12586242
Hwd. No. 12593660
2005 & 2006
Serv. No. 12589463
Hwd. No. 12589162
2003+
SERV. NO. - HWD NO.
2004
Serv. No. 12586242
Hwd. No. 12593660
2005 & 2006
Serv. No. 12589463
Hwd. No. 12589162
2003+
SERV. NO. - HWD NO.
2004
Serv. No. 12586242
Hwd. No. 12593660
2005 & 2006
Serv. No. 12589463
Hwd. No. 12589162
my computer numbers
serv. No. 12586242
hwd. no. 12583660
Test computer I got yesterday, doesnt have IAC drivers
serv. no. 12589463
hdw. no. 12589162
