New LS1 Owners - Newbie Tech - Po 0443 after ls6 intake intstall
Chaospartners
10-25-2010, 08:21 PM
Like the title says im get a 0443 code after the ls6 intake install.. I got a small vaccum line off the back off the intake. But it seems to short to reach over to the intake.. The code is evap purge valve fault or something like that i checked it at work the other day and cleared it and the next time i started it came right back on.... Do u guys think this small vac line off the back is my problem? I wanted to see before i pull the intake and look again to check..
01ssreda4
10-26-2010, 12:31 AM
Yes there is a small vac line on the back of the intake.
Chaospartners
10-26-2010, 07:05 AM
Is that the reason the car is throwing the evap code?
disc0monkey
10-26-2010, 10:50 AM
check your red plug into the canister(purge valve) near #3 injector.
99% its that
Chaospartners
10-26-2010, 12:37 PM
YEP thanks guys im a dumbass and forgot to plug it in!! lol
disc0monkey
10-26-2010, 12:55 PM
i forget that one EVERYTIME lol
Chaospartners
10-26-2010, 03:23 PM
Thanks!!
BlackScreaminMachine
10-29-2010, 03:00 PM
Not a big issue. I actually had a vac line which is used for HVAC get pinched on a intake re install and due to getting rushed I had a horrible running car, no A/C or any HVAC controls. Took the intake off and had to get some vaccume line and fixed all.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
