Fueling & Injection - Is there such a thing as a low pressure intank pump
rickou812
10-26-2010, 01:02 AM
I am thinking about doing a 2 pump in tank setup with a twist. I would like to use 1 for my fuel injection (high pressure) and 1 for nitrous (low pressure).
Thanks,
Rick
badcoup
10-26-2010, 11:15 AM
the tbi camaros and trucks had a low pressure in tank typically 13 psi
JasonWW
11-01-2010, 04:29 PM
I'd like to add one to push fuel back into the bucket. Has anyone done that?
Frost
11-01-2010, 04:40 PM
what??
JasonWW
11-01-2010, 04:55 PM
I am thinking about doing a 2 pump in tank setup with a twist. I would like to use 1 for my fuel injection (high pressure) and 1 for bucket filling (low pressure).
Is there any aftermarket pumps that have that extra output like the stock pump?
I need a replcement pump, but really hate to loose the bucket design.
I was thinking of adding a tiny 24v pump run at 12 just to fill the bucket, or something similar. Maybe a tiny external pump?
Lonnies Performance
11-01-2010, 05:36 PM
To the original post, 2 pumps would be possible, but plumbing gets complicated for 2 complete systems back to the tank. A front stand alone may be better. You can also tee off the front supply line to the nitrous with a deadhead style (non-return) regulator, dropping pressure to the needed value without running 2 complete systems.
Jason,
Good replacement pumps have the venturi setup, no need to invent something that is not needed. I can check, but I believe they even work at low pressure in the camaro. Feel free to call me if you are interested in a system for your car.
JasonWW
11-01-2010, 05:39 PM
Lonnie, thanks to your explanation of how the venturi system works, I found the Racetronics F99 pump that has that extra output. Is that the pump a lot of folks are using?
Lonnies Performance
11-01-2010, 09:45 PM
Yes,
Those are the ones I sell.
massls1guy
11-01-2010, 10:32 PM
I just installed the racetronix "FPM-001 - Fuel Pump Module, 99-02 GM F-Body, Complete". All new bucket, pump, sock, float, etc. Works great.
Meemperor
11-02-2010, 05:50 PM
http://www.nitrousoutlet.com/catalog/categories.asp?category=24§ion=73
One of those with a Racetronix pump would suit your needs very nicely !
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
