What to use for lid gasket?
I have a lid that is not sealing adequately. It needs a thicker gasket.
What can I use to give it a good seal? Something 2x stock thickness should work great.
Cool, worked well, for some reason, my lid locks (the two things that hold it down in the front) don't work so well with my new lid, any ideas on how to fix this? They snap down but come loose if you budge it.
Did you do the foam on it yet? That might help make those clamps tighter, also make sure you have the lid on right. If that doesn't help maybe double layer the foam to get the clamps to stay tight. Different air filters are different sizes so not all combos work good.
