General LSX Automobile Discussion - Need an Excuse
Gaunt's_Girl
10-27-2010, 11:51 PM
Ok, so I'm in college and still live at home. My parents kinda freak out when I "spend money" on my Camaro i.e. mods.
My boyfriend bought me 3.73's for my Birthday and the car is headed to the shop hopefully on Monday. SO, I need a good sounding excuse for why my car has magically disappeared.
I have a Silverado as my DD and if both cars are gone, they will know something is up. Only issue is my Dad kinda knows cars, so I can't just make up something from left field, and I can't just make something up about maintenance.
I need help in order to save myself the headache from the "saving your money" lecture.
Thanks! :P
99FormulaM6r
10-27-2010, 11:55 PM
Could always just say your boyfriend paid for it....
Gaunt's_Girl
10-27-2010, 11:56 PM
Well, he did pay for the gears, but I'm paying for the labor.
Plus, I don't want to throw him under the bus!
Starz T/A 17
10-28-2010, 12:36 AM
I would just be honest and say that you got the gears for a gift, and want to get them installed. Its not like your spending thousands of dollars or hurting the reliability of the car, so whats the big deal? When I was in college my parents gave me the same lecture as im sure many others on here got. But Id much rather be an adult about it and be honest opposed to lying about it to them. Just my 2 cents.
But as far as an excuse good luck with that, my dads a car guy too, and IF I ever thought about or mentioned the idea of taking my car to a shop he would want to look over it (regardless of the problem) to see if he could save me some money and fix it
RPM WS6
10-28-2010, 12:46 AM
When you lie to someone who has a clue about the situation (you said he knows cars), you must keep things simple, easy to remember, and use as much truth as possibile. In this case, considering the many ways that you could possibily be caught, keep the story related to the area that's actually being worked on.
Tell him that you noticed a bit fluid staining in the area of the diff, and took it in to have it checked out. Turns out the pinion seal was leaking (common issue on these cars, totally beleiveable), so you had it replaced. If you think he'll go so far as to inspect it closely, then get under there with a pressure washer at a car wash before you bring it home. Tell him you cleaned it up to make sure it wasn't leaking after the repair. Simple and closely related to the actual work being done making it damn near impossibile to be caught. :)
Gaunt's_Girl
10-28-2010, 12:55 AM
I like it, thanks!
Yeah, he won't go so far as to inspect it.
And I'm considering just saying "I'm having some work done to it," and leaving it at that since there isn't really going to be anything visibly different with my car, but we'll see. Just trying to brainstorm a few ideas lol
RPM WS6
10-28-2010, 01:11 AM
I like it, thanks!
Well, knowing that they freak out about unnecessary money spent on the car, an open-ended statement like that may lead to suspicion that'll make any story you might tell later hard to beleive. Then the truth comes out, plus the fact you lied, and everything you wanted to avoid in the first place is now even worse.
You gotta do what you feel is right. Generally I'm not the sort that would suggest lying, but in this case I get your reasoning. Considering the situation doesn't effect them at all, I can see why it's just easier to avoid the conflict.
Camaro_94
10-28-2010, 11:44 AM
Just tell him the truth and be upfront. Say you got them as a gift. Labor shouldnt be that bad anyway. Guaranteed this convo would be much more smooth than if he found out you were lying.
omarrakeen
10-28-2010, 11:55 AM
bfft parents! excuse is going to some cars show or a deep car detail :lol: gd luck. am thinking about doing 3.73s as well but its my DD am afraid that car wont be good for that..would that hurt mpg alot?
lt1pwr1
10-28-2010, 11:58 AM
I think the real question is: where do I find a girl who is into cars as much as you? :D Seriously, all I get from girls are "why is your car so loud, do you need to fix it"? And I only have a catback on it. In all seriousness, I would tell him the truth then tell him you'll let him drive it after, then he should be ok with it :nod:
Plus, just noticed you live at home. Think of the money you are saving by not going away to college! Throw that one at them too, I used to do it all the time when I was in college when the rents didn't approve of my spending.
RPM WS6
10-28-2010, 12:38 PM
Honestly, I would not even consider doing an gear swap on one of these cars with an A4 until after doing a TC. The 4L60E has a very aggressive 1st gear, and can launch well even with little 2.73s. What you need is more stall. 3500 or so for a stock car is about perfect. The gains will be MUCH greater than going to a 3.73 gear, and without any of the highway MPG loss (once the TC is locked, cruising rpms will be exactly the same as stock).
LOL! Good girls like this are out there. I married one of them. Every time I make one of my cars louder, she tells me it could still be a bit louder and be OK. One day I'm going to just run open headers on everything and see if that makes her happy. :devil:
thunderstruck507
10-28-2010, 12:52 PM
bad bearing on the differential, rear end was making noise...boyfriend got you gears as a gift since it was going to be apart anyway
nemss1
10-28-2010, 04:29 PM
hell, if u have to lie, if hes driven the car before, if he drives it after the gears, he may notice a slight difference in its drivability seeing he knows cars and such
Gaunt
10-28-2010, 04:44 PM
We are pulling the stall out of my car when I do the 4L80E swap, so that's what we are waiting on in that department ;)
For what It's worth, I asked if it would be easier to tell the truth, or make up a convincing story.
RPM WS6
10-28-2010, 05:14 PM
Sounds like you guys have a good plan then. :)
If you two are planning to do additional work to the car, then these "stories" might get suspicious. Guess it depends on how often the car will be gone, and for how long each time.
sundaydriver
10-28-2010, 06:01 PM
Woman, just man up to what is being done to the car!
jdmotox333
10-28-2010, 06:05 PM
would you happen to have a twin sister with the same love of cars. willing to move to anywhere close to her :D the girls around me here in maryland has as much intrest in cars as a police officer pulling someone over and not giving them a ticket/ warning
D00z28
10-28-2010, 06:16 PM
I like the pinion seal Idea prolly needs one anyways.
jdhedman
10-28-2010, 06:34 PM
tell him you are getting your rear gear oil changed.. its not a lie.. just a half truth
omarrakeen
10-28-2010, 06:52 PM
[QUOTE=RPM WS6;14050882]Honestly, I would not even consider doing an gear swap on one of these cars with an A4 until after doing a TC. The 4L60E has a very aggressive 1st gear, and can launch well even with little 2.73s. What you need is more stall. 3500 or so for a stock car is about perfect. The gains will be MUCH greater than going to a 3.73 gear, and without any of the highway MPG loss (once the TC is locked, cruising rpms will be exactly the same as stock).
just what i wanted to hear :lol: thanks man and sorry op for the hijack :lol:
01formula6
10-29-2010, 10:53 AM
I'll play devils advocate. Your parents do have a point about not wasting money on mods considering you are still living at home and are in college. Are you paying them rent, do you pay for your college, do you have a job? If you answer "no" to any of these questions then they might have a right to voice their opinion on where your money is spent. Their reasoning will be that any money spent on mods could have instead been saved, so you can move out of their house.
CranMaro99
10-29-2010, 01:24 PM
Yup. I'm a big fan of just being honest in life, because I've also learned it makes life much easier (even though at times it doesn't seem like it will.)
Gaunt's_Girl
10-29-2010, 09:00 PM
Well, you can go play devil's advocate somewhere else.
I work at a financial institution and my major is in financial management. I am very good about saving and budgeting my money and I know my limits.
:gtfo:
01formula6
10-31-2010, 05:20 PM
Well then, everything seems under control. Please resume plotting how to best lie to your parents :disgust:
SSmoken
11-01-2010, 12:31 AM
get new parents
Johnny-LT1-runner
11-01-2010, 07:38 AM
get new parents
Haha, ^^^this.
There's nothing worse than a woman who lies, then again all women lie.
Honesty is the best policy, so don't be a bitch, tell the truth!!! :D
hurley711
11-01-2010, 08:19 AM
Act like an adult and tell them the truth? Getting away with little lies makes it easier the next time, and the next time, and the ...
Gaunt
11-01-2010, 11:02 AM
Turns out if they are gone for the day, and a gear install only takes a day, they don't need to know anything.
Lie of omission isn't really a lie (sometimes) ;)
94 Camaro Z28
11-01-2010, 07:37 PM
How long have you and your boyfriend been dating? This sounds like a good anniversary type present. Except vice versa of course, girls around here only use cars to go to the mall :(
Gaunt's_Girl
11-01-2010, 09:38 PM
See Below.
:thumb: Gears are in, car is back in the garage. If they ask, I will tell them.
Just shy of four years. It was a GREAT present :D Yeah, we have fun buying mods for each other for Birthdays, Christmas, and Anniversaries lol
WS6 Rampage
11-02-2010, 02:07 AM
Just say that it broke down and your getting the rear diff fixed!
sykodrummer9800
11-03-2010, 08:44 AM
Right! count me in!! :angel:
sykodrummer9800
11-03-2010, 08:45 AM
See Below.
wish there was more women like you... i get clothes :bang:
