5-30 or 10-30
Originally Posted by 2KSSLS1
i was wondering that im burning oil on 5-30 should i move up to 10-30..??/
You should look at the viscosity of the oil and not just the weight. Some 0w-30 oils are heavier than 10w-30 oils. For example Redline 5w-30 is 10.9 cst@100*C and Redline 10w-30 is 10.7 cst@100*C. German Castro Syntec 0w-30 is heavier than both of the other oils it is 12.2 cst@100*C. Check out www.bobistheoilguy.com
Pg 8 of the LS1 Engine Kit Installation Guide specifies, and I quote, "A 10W-30 synthetic oil is suitable for most operating conditions. Operating in extreme heat or cold may require oil with higher or lower viscosity respectively."
Straight from GM.
Straight from GM.
