dimond piston Problem !!!!!!
Old 10-28-2010, 06:25 PM
NAVY's Avatar
Angry dimond piston Problem !!!!!!
Hi guys i need some info pls
i have piston dimond ( bore 3.905 , strock 3.622 , rod 6.125 , C.D. 1.310 ) so when i go eagle wibsite ... http://www.eaglerod.com to check my engine compression the web give me ERROR is that ok ? or thare is somethink wrong ?
i have finished the engine and start the car and soon i will run pro F1A 18 psi any idea whats wrong with my car project ???
thanks
navy
Old 10-28-2010, 06:33 PM
KCS
Moderator
KCS's Avatar
Originally Posted by NAVY
my engine block 5.7 L ( 9.240 dick height )
Wait...what?
Old 10-28-2010, 06:40 PM
01wssick's Avatar
Originally Posted by KCS
Wait...what?
lol free bump.
Old 10-28-2010, 07:50 PM
NAVY's Avatar
Do you have any advice pls
This question is not for the children sorry
Old 10-28-2010, 08:06 PM
KCS
Moderator
KCS's Avatar
LOL children? Look at your spelling and grammar kiddo.
But yes I do have advice for you: learn how to calculate compression ratio for yourself. It only involves very simple algebra and will help you learn the concept much better as well as to understand what changes to the engine affects it.
What "error" are you getting? I put in the numbers myself and didn't get an error. There is a little "warning" box that pops up to tell you that your piston is above the deck surface, but no "error" message.
Old 10-29-2010, 12:49 AM
Whiteaw57's Avatar
this calculation is simple its the total volume of the cyl when the piston is at bottom dead center vs the volume when it it at the top. Start by calculation what the volume of the cyl itself is. Basically just (pi*r^2)*h so (3.14*(3.905/2)^2)*3.622 you will subtract that from total volume which is that number, plus the volume IN CUBIC INCHES NOT CC's of the headgasket and the piston dish and the cylinder head, note also that one inch=2.54 cm. If you need cubic inches you have to cube that converison factor so...1in^3=16.378cm^3.
Old 10-29-2010, 05:21 PM
NAVY's Avatar
Do you mean that there is no risk in my engine ?
Old 10-29-2010, 05:44 PM
KCS
Moderator
KCS's Avatar
There is a risk in any engine, yours included. The warning on the website is simply saying that your piston will come above the deck at TDC so you need to make a headgasket choice accordingly. Stock GM MLS gaskets are typically .052" thick so the piston can come up about .010-.015" before you will run into trouble.
Old 10-29-2010, 08:34 PM
NAVY's Avatar
I understood now
Thank you to help me KCS
Old 10-29-2010, 11:07 PM
DaveX's Avatar
I think the internet has been seriously detrimental in a large portion of the population's ability to spell and use proper grammar. I see this on most of the forums that I frequent.
