Drag Racing Results - Another ram air test. Proof it works.
senicalj4579
10-30-2010, 11:35 AM
I ran the car with the ssra on the car first few times at the track. A few weeks later I decided to take it off to make room for a trans cooler. Went to the track and wasnt happy with the time I ran. So...I decided to put the ssra back on.
This wasnt meant to be a test to see if the ram air actualy works...I was only trying to make room for the cooler but I ended up with some concrete results that proves ram air works.
(With ssra)
DA -249
1/4 12.740 @ 109.22
http://www.ls1tech.com/forums/12-second-club/1330972-12-740-last-night-new-england-dragway.html
(took ssra off)
DA -778
1/4 12.9 @ 107
I didnt save my slips for these because I wasnt happy with them but I can tell you ALL the numbers were not as good. I think best 60'was like 2.1xx.
(put ssra back on)
DA -1245
1/4 12.638 @110.04
http://www.ls1tech.com/forums/drag-racing-results/1345012-new-best-ned-12-6-a.html
Now to me this is concrete proof that it works. EVERYTHING else on the car was the same BUT the ssra. DA was different but as you can see the car did better with the ssra in worse DA! Thats proof right there:nod:
TXCAMSS
10-30-2010, 12:07 PM
That's good info. I have always seen good gains running the SSRA kit as well. Your numbers add up right based on the DA on each of those runs with the SSRA installed.
Thanks for sharing the detailed data to support the gains.
senicalj4579
10-30-2010, 12:15 PM
No problem. I just wish I still had the slips from when I took the ssra off. It didnt dawn on me to post this info untill I saw another post questioning r/a this morning. So I didnt think back then to save them. But like I said its very clear. Obviously better throttle response and far better et and mph.
Also what I didnt mention is that the 12.9 without ssra was the best of the night. Without the ssra actualy put me back at 13.0s for a couple passes.
Ls1Rook
10-30-2010, 12:25 PM
I'm Trapping 111 with bolt ons now do you think i will gain maybe a mph with a ram air?
senicalj4579
10-30-2010, 12:40 PM
The evidence says yes.
AChotrod
10-30-2010, 04:29 PM
Every car I have ever seen use a similar set up goes .1-.2 faster and gains 1-2 MPH.
JBarron
10-30-2010, 04:42 PM
Do you have the ability to see the IAT readings on your car?
senicalj4579
10-30-2010, 05:27 PM
IAT stay pretty much consistant with outside air temps (a little higher).When your on the highway and you give it some gas the IAT drops a couple degrees. Never watched it while at WOT though. Probly drops a few more.
When I took the CAI off the car IAT were very high after the car had been sitting (heat soak). It still dose heat soak with CAI but not like without CAI or not like if you had a metal CAI kit.
Edited...
I watched it a little closer yesterday when I started the car up. It still does heat soak a good amount with the CAI. IT was at 105f when I started the car. But temps start dropping even while idling after startup. Then as soon as you start driving temps drop fast. Temps drop really slow without the CAI.
rob69zombie
10-30-2010, 05:49 PM
Awesome results and good thread buddy. :)
JBarron
10-30-2010, 06:23 PM
When I took the CAI off the car IAT were very high after the car had been sitting (heat soak) but now CAI is back on the car IAT are not much higher than outside air temp. It still dose heat soak but not like without CAI or not like if you had a metal CAI kit.
Another thing is when I didnt have the CAI the IAT would be in the 100s after car had been sitting. It would take 10-20 min of highway driving to lower IAT and it still wouldnt be as low as a CAI kit.
With the CAI the IAT are pretty much low from the start.
It seems evident that you are going faster with the SSRA, but I think it would be interesting to collect some evidence of why. If we could see MAF or MAP logs, as well as IAT logs, to compare between having the SSRA on, and not having it on, I think that would be interesting. I feel that this would paint a more complete picture of what is going on.
This is a pretty interesting result, by the way, thanks for sharing it. .2 seems like a big difference. I like that about these engines, things that would not really be definitively measurable on smaller (or lesser) engines, become more obvious, which is awesome.
senicalj4579
10-30-2010, 07:23 PM
Heres some info that might sooth the obsession a little....
http://www.installuniversity.com/install_university/installu_articles/ftra/ftra_12.262000.htm
Joshiedoom
10-30-2010, 08:02 PM
Its hard to see spending money on this little piece of metal but the results back it...Its more cost effective then a gear install as well.
JBarron
10-30-2010, 08:49 PM
I am just interested in the science behind all kinds of things having to do with cars. Please don't think I'm questioning the product or the results. I'm just curious about why it works. The science behind the controversy surrounding this is certainly above my head, so I don't want you to get the idea that I even have an opinion as to whether a ram effect can increase manifold pressure (actually, my opinion, if anything, would be that it can - I only would dispute a claim that this constitutes proof that the gains are due mostly to an increase in manifold pressure).
I don't have a car that can use any of these products, but I'd like to fabricate something for it, and I'd like to understand the best way to do that. I'm also all for incremental gains, so if I can get even .1% more VE, on top of gains from cooler air, or resonance effects, I'd definitely take advantage of it.
Competition GT
10-31-2010, 09:08 PM
Don't suppose you logged the map sensor on the three passes?
green28
11-01-2010, 09:20 AM
What were your 60 ft times for all of the runs?
senicalj4579
11-01-2010, 09:26 AM
Yea theres alot to get into and obsess about. Iv been trying to step away from it a bit lol im into my car to much as it is :nod:
senicalj4579
11-01-2010, 09:27 AM
No I dont. Wish I did though.
senicalj4579
11-01-2010, 09:36 AM
1st and 3rd 60's are listed in the threads attached. I dont have an exact 60' to tell you for the 2nd (the one without ssra) because I was so disapointed I through the slips out. I remember looking at them though and ALL the numbers sucked and I considered it a wasted trip. But I can tell you I was only doing 12.9s,a couple 13.0s,and like I said best 60' was in the 2.1xx area. Mph was down to 106-107 and 1/8 was down to 86mph.
When I took the ram air off I knew I might be disapointed when I went to the track but I didnt think it would have this big of a difference. So I couldnt live without it and I put it back on my car.
green28
11-01-2010, 09:52 AM
Gotcha, didn't catch the links. Although the 1.9 60's compared to your 2.1 60's could be your .2-.3 difference. The SSRA is going to have little to no affect on your 60' times. Not trying to take away from your results just stating my opinon on the possible difference in et. Looks like you definatly gained some MPH with the SSRA though.
I ran yesterday with the chris1313 ram air and gained a mph over my previous best, but unfortuanly don't know how much I lowered my et with the ram air. The only times I have to compare was my previous best of 12.6 @ 110 w/ 1.9 60' with only free ram air compared to the 12.03 @ 111 w/ a 1.61 60' I ran yesterday with the ram air installed and air box sealed.
senicalj4579
11-01-2010, 10:02 AM
The ram air deff did something for throttle response. My car isnt making a shit ton of power so I dont have a problem with being consistant on these hoosier drs. I did enough passes to believe that the ram air does help off the line. If its the availability for colder air right away or whatever I dont know. All I know is the proof has been proven
Seit
11-04-2010, 07:03 PM
I have combo
SSRA+box lid+filter k&n+descreened Maf +Smooth Bellows+ported TB
The gain in the track was 3.6tenths
I'm thinking about changing ssra to chris1313 ram air
but the problem is I need to remove the a / c
The difference would be 0.5,,,0.7 or 1 tenth ?? more?
senicalj4579
11-04-2010, 08:23 PM
I actualy got that ram air but on the hot summer day when I was taking my ac condensor out I decided it wasnt worth it. I needed to keep that ac man. So I evactuated the system,recharged it back up and sent the ram air back to speed inc lol. The ssra is good enough. And when I get the stall next year it will be even better.
GIVE EM' THE BIRD
11-12-2010, 09:18 AM
Does the lid seal any better with the SSRA??
Seit
11-12-2010, 10:03 AM
Does the lid seal any better with the SSRA?? of course
http://www.ls1tech.com/forums/generation-iii-external-engine/219517-report-air-lid-ssra-lid-seal-effectiveness.html
HioSSilver
11-12-2010, 11:36 AM
I sealed my SS hood the airbox years ago with back to back test's and it was worth a solid mph maybe a little more .
senicalj4579
11-12-2010, 03:45 PM
Idk how anyone could say any cai seals any different from eachother concerning the lid. Any cai you choose you will have to seal it up fully anyway. I use calk.
blk/slvr02ss
11-12-2010, 04:54 PM
Maybe i should put one on my car if it helps that much !!!!!!!!!!!!
Mike Morris
11-13-2010, 08:45 AM
I have the fast Toys and gained about a MPH with it. I also noticed my air filter gets dirty much much faster now.
Nice write up.
HioSSilver
11-13-2010, 09:10 AM
Nice write up.
That's why I use the hood. The filter stays much cleaner, and it works better.
mike c.
11-13-2010, 04:43 PM
What is a ssra??
Joshiedoom
11-13-2010, 05:30 PM
Gained around 2mph/.15et with the a direct flow lid and ws6 lower intake instead of slp lid and stock gutted lower airbox
Seit
11-16-2010, 03:40 PM
Nice write up.
SSRA or chris1313 ram air--->
more gain,, more air mass,, more oxygen,, more speed (venturi effect),, more mph = Increase in dust Particles (dirty) in the air filter
every action is a reaction
Solution?
http://www.summitracing.com/search/?keyword=k%26n%20filter%20&dds=1
http://www.jegs.com/i/JEGS/555/50015/10002/-1
http://www.slponline.com/view_product.asp?P=25017&BIG=25017-1
I cleaner the filter every 3 months (I need only 6 minutes)
BlackScreaminMachine
03-29-2011, 08:09 AM
If you can go to a track rental and do this experiment again, I bet you would get a more accurate result.
As long as the 60 foot and 330 look close as well as the DA then I am willing to wager you can account for the difference in the SSRA.
Also if you can hot lap it (which is possible at a rental) this would take many varibles out of the equations.
senicalj4579
03-29-2011, 10:32 AM
Well, as far as exactly how much gain it is I really dont know but I do know it works and worth it. If it wasnt, I would have a HUGE B&M trans cooler in its place:D
andy-lswon
04-12-2012, 11:19 AM
Awesome info here man
