Generation IV Internal Engine - LS6 springs question
grantn
10-30-2010, 04:45 PM
I was wondering if I can use the yellow ls6 springs with the ls9 cam. Cam specs are 211/230 .558/.552 122 lsa. How long will the springs last. The stock ls6 cam is 204/218 0.551/0.547 117 LSA. The lift is not that defferent.
ThanX
pHEnomIC
11-02-2010, 03:12 AM
I feel that those springs probably would work with that cam, however i would not use them.
Call comp cams or something, they should be able to tell you for sure.
By going to some nice aftermarket springs, you get some added stability up top so its definitely a worthwhile upgrade.
Also, might want to look into this:
http://www.ls1tech.com/forums/generation-iv-internal-engine/1039869-ls7-valvesprings-600-lift-cam-instead-918-springs-hmmm.html
TurboBuick6
11-02-2010, 08:01 AM
Get some good reliable springs in there.
grantn
11-02-2010, 11:00 AM
I already have the ls6 springs. I want to run them for 15-20k then change them for something with higher lift. Will they last that long?
1lejohn
11-02-2010, 12:58 PM
They will work fine with the cam, but what heads are you using.
disc0monkey
11-02-2010, 01:15 PM
it'll be fine.
grantn
11-02-2010, 03:38 PM
L92 heads with ls2 block
Silvy6.0
11-02-2010, 03:40 PM
I would go with a good set of springs. It sucks when you get on it and you have that little bit of doubt. Just an uneasy feeling. You should be fine. But just keep that in mind.
1lejohn
11-03-2010, 10:59 AM
I would run a better spring with those valves. A Pac 1218, or 1518 they are both beehive, and fit those heads.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
