LSWNDR
10-31-2010, 01:59 PM
So the question i have for you builders an tech members is if you have a stroker motor with a heavy bottom end is it not suppose to be revved out to high rpms or is that a myth?
pHEnomIC
10-31-2010, 03:41 PM
With a stroker, you have more motion and more friction given the same rpms because the pistons are moving farther. Technically, the top possible rpm would be diminished because of this, however the top end is usually the restriction on a properly set up forged engine.
With a top end designed to handle high rpm operation (lightweight, durable stuff, solid roller, etc), you can still rev these things pretty high.
I dont really have too much attention in high rpm top end stuff and i wouldnt be too worried about revving my 404 to 7500ish without changes.
racer7088
11-01-2010, 10:31 AM
Yes as was said above the problem is usually the top end feeding the bottom end and any of the aftermarket rods can generally take anything you can dish out to it.
