Oil Pan Rough Casting, Bead Blast Inside?
Old 10-31-2010, 05:05 PM
NovaKid's Avatar
Default Oil Pan Rough Casting, Bead Blast Inside?
Hi everyone, I just swapped my oil pan from a stock CTS-V pan to an F-body pan. The inside of the CTS-V pan I took off was flawless and smooth. The F-body pan I ordered from a Chevy dealership had really rough casting marks and slag on the inside bottom of the oil pan. It's pretty rough on the inside surfaces. Should I get the inside of the pan bead-blasted or does this even matter for oil flow? Has anyone else seen this type of thing before?
Old 10-31-2010, 07:23 PM
ShevrolayZ28's Avatar
Yup, mine is the same way. At first I thought it was loose debris, but no, it's left over from their casting process. I wouldn't worry about it.
Old 10-31-2010, 07:33 PM
tittan1500's Avatar
Mine is the same way dont worry
Old 11-01-2010, 12:13 AM
NovaKid's Avatar
Hey thanks guys, I appreciate your input.
Old 11-01-2010, 01:27 AM
01ssreda4's Avatar
Considering the oil is just draining into the pan the rough casting won't have any negative effect. My brand new pan from GMPP sounds exactly as you described.
Quick Reply: Oil Pan Rough Casting, Bead Blast Inside?
