What size injectors?
Old 11-01-2010, 10:14 AM
Rise of the Phoenix's Avatar
Default What size injectors?
I need some help in picking the correct size injectors for my build. 02 WS6, 6 speed, long tubes, true dual exhaust and will be adding AFR 205 62cc heads and the F14 112 LSA cam. Thanks for the help guys.
Old 11-01-2010, 10:23 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
We sell some of the racetronix 37lb injectors. They would hold this set up pretty easily and only come in at $320.00 for 8.
Old 11-01-2010, 10:49 AM
mtuggle86's Avatar
imo if you not running a power adder and that's all you plan on doing to you car I would just buy some used svo 30lb injectors. I got my set for 113shipped and there like brand new there the bosch design 3 style too.
Old 11-01-2010, 11:01 AM
mtuggle86's Avatar
Btw the bosch are 36lb on ls1 fuel pressure
Old 11-01-2010, 01:06 PM
My friend, who is a mustang guy, said something about green top ford injectors. Would those work?
Old 11-01-2010, 01:29 PM
mtuggle86's Avatar
Yes there the same as the svo 30lb injectors (redtops) except the greentops are 42lb injectors
Old 11-01-2010, 01:34 PM
Would it benefit me going with the green tops if I plan to spray latter on? Also, do I need different injectors with the head and cam swap?
Old 11-01-2010, 03:35 PM
mtuggle86's Avatar
Yes If you planed on doing a dry kit later the greentops would be better. If you plan on sticking with NA and are done modding Id just get some redtops.
Old 11-02-2010, 09:06 PM
Mac 2002 SS's Avatar
FAST 36 lbs Injectors from TSP gets my vote .
Old 11-02-2010, 09:09 PM
11seccamaro's Avatar
shouldnt stock injectors be fine for this setup?
Old 11-02-2010, 09:25 PM
flintwrench69's Avatar
Cam only yes. Cam & heads no. I run Ford greentops & new they were $330.
Old 11-02-2010, 10:28 PM
SOMbitch's Avatar
FYI the Greentops flow about 48#'s at our fuel pressue and are good to over 600rwhp on our cars.... I have the bosch design III 42#'s (48# bar 4) and they work super on my mild car and I have plenty of room to grow... Got a pretty good deal on 'em in here....
Really though some Redtops should be plenty for you and can be had on here in the $125 range....
Old 11-03-2010, 06:06 AM
Higgs Boson's Avatar
The greentops don't have good low pulse width characteristics. Your ECM will be working hard to keep them in line at idle and cruise. They are cheap but I don't recommend them unless you really need something that big.
With that said, I'll be happy to sell you mine... :-)
