fuel
Old 11-01-2010, 04:21 PM
racerrit's Avatar
Default fuel
On a 2000 z with heads n cam upgrade n ls6 intake do i need bigger injectors?
Old 11-01-2010, 04:50 PM
Jon@Texas-Speed's Avatar
Depends on the heads and cam setup. If it is fairly aggressive you will more than likely want to upgrade the injectors. Throw it on the dyno and see what the injector duty cycle is with the combo. That will tell you if you are out of fuel or not.
Jon
Old 11-04-2010, 05:38 PM
racerrit's Avatar
Jon
Cool thanks, I heard Giglioti was a sponsor on here im rebuilding from the ground up his old 2000 Z28, bought it as a roller
