what head gaskets should i run with my setup?
Old 11-06-2010, 09:58 PM
AAK z28's Avatar
Default what head gaskets should i run with my setup?
Wondering what head gaskets to run with my setup in signature ?
Old 11-07-2010, 12:40 PM
AAK z28's Avatar
Any ideas?
Old 11-07-2010, 05:45 PM
Fastdriver1992's Avatar
not sure of the T-rex cam specs but r u asking what thickness to run or what brand? u can never go wrong with a cometic gasket
Old 11-08-2010, 07:43 AM
CRAZZ28's Avatar
stock replacement gm mls gaskets. i think they are like $40ish/pair.
Old 11-08-2010, 08:36 AM
blsnelling's Avatar
I wouldn't consider anything but GM MLS gaskets. Too many reports of problems with Cometic, unless you have freshly machined surfaces on both the deck and heads with the correct finish.
Old 11-08-2010, 10:16 AM
Jon@Texas-Speed's Avatar
GM MLS head gaskets would be what I would put on it. That's a pretty aggressive size cam so I wouldn't put any thinner gaskets in it. We have them on the shelf if you need a set!
Jon
