Signature Testing & Design - Failed sig test inside...
View Full Version : Failed sig test inside...
faster_n_you98
11-07-2010, 09:17 AM
My signature will not show despite me uploading it. I tried 3 different pics and none do. also it doesnt have any errors or say they are too big or anything.
what do i need to do to make it show up?
Thanks
JeremyT
11-07-2010, 03:57 PM
I fixed your signature. The last step of the process, when uploaded a signature is to click on the Insert Signature Picture option. This inserts a set of [noparse][noparse] tags into your signature so that your uploaded signature is parsed in your signature. It appears you did not do this step, so I manually added the tag in your signature.
Also, I edited your post above to select the "Show Signature" option. By default, if your signature is blank (which it initially was because you didn't have the [noparse][noparse] tags), that option is automatically deselected at the time of your post. I edited your post above to select that option, so you can see the signature is working.
faster_n_you98
11-07-2010, 09:08 PM
Thank you very much!
yahoodeno
04-07-2011, 04:56 PM
yeah im having the same problem
