Easiest way to turn motor over??
Old 11-08-2010, 09:30 AM
Nastyc4's Avatar
Default Easiest way to turn motor over??
was going to adjust my lifter preload and wanted to know what the easiest way to turn the motor was.
thanks!
Old 11-08-2010, 09:37 AM
djfury05's Avatar
I would say put it in neutral and get a rachet and socket to fit the crank pulley bolt, and then a long extension you can run to the top of the motor and do it that way
Old 11-08-2010, 09:48 AM
Nastyc4's Avatar
I know on my LT1 I just hit the alternator pulley bolt, pressed on the belt with my other hand and I was able to turn it over.. just unsure on the ls1. Im not sure if Ill have an extention that is long enough from the crank bolt but maybe I can reach down there. thanks !
Old 11-08-2010, 10:14 AM
01ssreda4's Avatar
Pull the plugs out, that will make it a lot easier.
Old 11-08-2010, 10:40 AM
Jon@Texas-Speed's Avatar
Pull the plugs and put a socket and rachet on the crank bolt. A lot of old school guys used a remote starter switch from the starter and bump the motor over a little at a time. Either way will work.
Jon
Old 11-08-2010, 10:43 AM
babbage1109's Avatar
Flip the car...then you can totally turn the motor over...jk
Old 11-08-2010, 11:37 AM
Nastyc4's Avatar
Lol my buddy said to pour 2 cans of beer in the oil lmao
