Gen 5 Camaro Internal Engine Tech - Katech Torquer LS3 cam test results
Katech_Jason
11-08-2010, 09:36 AM
This camshaft was tested last year by GM High Tech (http://www.gmhightechperformance.com/tech/lsx_engine/0911gmhtp_chevy_ls3_engine_camshaft_comparison/index.html) and scored very high overall in each category. We wanted to get some data on our own engine dyno to show the results with WCCH ported LS3 heads and validate our LS3 Camaro & Corvette head/cam package.
Engine: LS3
Camshaft: Katech Torquer LS3 224/236 .581/601 113LSA
Heads: WCCH CNC-ported LS3
Dyno headers
C5-R timing chain
Halltech air intake system
Everything else on the engine is stock
531hp, 480 ft-lbs
http://www.nexternal.com/katech/images/C2-9213_11.jpg
http://store.katechengines.com/torquer-ls3-camshaft-p221.aspx
redsap05
11-18-2010, 07:35 PM
is this at the wheels? If not than not to impressive.
xx_ED_xx
11-19-2010, 07:06 AM
head work and a cam I think it aint bad at all
Katech_Jason
11-19-2010, 07:12 AM
This is at the crank. 531rwhp would be 625 at the crank using our chassis dyno. Impossible from a mild head/cam 6.2L. Look at the cam specs. This is a mild, very drivable cam. We weren't going for the most radical, highest horsepower, non-drivable cam package here.
Martin718
11-19-2010, 12:39 PM
just curious when doing a cam swap i see allot of people do the timing change swap too.
Well i just took my car to a shop and he doesnt want to change the timing chain said not needed and al;so tends to be timing chain clearance issues.
do you think its just the shop not wanting to do the timing chain or what??
zach
Katech_Jason
11-19-2010, 12:45 PM
zach
Some people have been breaking LS3 chains. We and many other performance shops always do a C5-R timing chain when doing a cam package. He probably doesn't want to deal with fitment problems of aftermarket timing sets, but with the C5-R you don't have to worry about that. It is a direct replacement chain that fits on the production sprockets.
Right now when you buy a Torquer cam, springs and retainers you get a free C5-R timing chain when you use the coupon code Torquer. If you just need the chain they are 15% off with the coupon code C5R.
Martin718
11-19-2010, 01:17 PM
Ok, are the chains in stock and any way to get one too jax fla by Monday??
Cost??
Katech_Jason
11-19-2010, 02:04 PM
Cost??
In stock
$149.99-15%=127.49
Cutoff time is 3:00 but if you get one in ASAP I will do my best. You'll need to select overnight shipping to get it there by Monday. You can order online here:
http://store.katechengines.com/c5-r-timing-chain-p30.aspx
01ssreda4
11-25-2010, 02:15 AM
Why would you name it torquer when TSP already has a cam named this? They run out of names in the cam name book?
Katech_Jason
11-29-2010, 10:14 AM
We've been using the Torquer line of camshafts since 2005.
01ssreda4
11-29-2010, 10:40 AM
Im guessing these camshafts by their respective companies are in no way affiliated? Just makes it kind of confusing in a way.
Katech_Jason
11-29-2010, 11:15 AM
Correct
