LS7 LUK OEM unsprung Clutch disk? Help ID
Old 11-08-2010, 02:30 PM
jlee29's Avatar
Default LS7 LUK OEM unsprung Clutch disk? Help ID
I Purchased a T-56 to put in my LQ4/9 from a guy on here and it came with a brand new LS-7 Clutch and used Fidanza aluminum Flywheel.
I am now ready to install but have noticed that the Clutch Disk is Unsprung!?
I have done a lot of research and can not figure out where this disk is from. I called the maker of the clutch LUK (maker of some GM OEM clutches) and none of the numbers matched there files for a LS7. And he said it indeed should be a sprung disk, not solid. Everything bolts and lines up fine... Can anyone explain my phenomenon?
Photo's :http://flic.kr/p/8RRjqg http://flic.kr/p/8RRmwe http://flic.kr/p/8RRo5P
Old 11-08-2010, 05:13 PM
jlee29's Avatar
Did they make an OEM Clutch for an LS7 with a solid un-sprung disk?
Old 11-08-2010, 05:20 PM
Darkman's Avatar
CTS-Vs (2004--2005 LS6s) (2006-2007 LS2s) come with dual mass-flywheels (sprung) and Unsprung clutch discs. The LS7 clutch and flywheel will fit these cars with the right slave. You may have one of those unsprung CTS-V units.
The original part number on 2005 CTS-V was 12568368, but GM changes part numbers from time to time.
Old 11-08-2010, 06:09 PM
jlee29's Avatar
Thank you "Darkman" I think that is exactly what I have.
Quick Reply: LS7 LUK OEM unsprung Clutch disk? Help ID
