What are the neccessary sensors i should run on my ls2
Old 11-08-2010, 07:47 PM
firehawk68mcleod's Avatar
Default What are the neccessary sensors i should run on my ls2
Im planning on building my ls2 to a 402 d-1 procharged with a custom tune.. what are the necessary sensors i should keep.. i know some people delete some... for example, i bought my procharger kit used and they sent with the kit a hollowed out mass air flow sensor....
Old 11-09-2010, 01:29 PM
sssalah's Avatar
No need to run a maf if going with a speed density tune, o2 sensors wont be required with open loop tune although not recommended with street use. EGR and EVAP are emission stuff depends on where you live and how the car will be used. Rest of the sensors like TPS, MAP camshaft and crank sensors can't be deleted.
