LS4 Performance - 3.29s or stock?
2005gxp
11-08-2010, 08:13 PM
What are the pro's and cons to going to a 3.29 gear in my gxp?
06 SS
11-08-2010, 09:10 PM
pro would be that your speedometer would be accurate as you already have 3.29 as the final drive ratio. If you mean changing the chain/sprocket reduction from the effective 2.93 ratio to get to a true 3.29 final drive, then I would suggest no. Your turbo will severely traction-limit you with the stock set-up, much worse if you shorten up the gearing. Also, the turbo will like the extra load the engine sees with the stock gearing and spool faster. Only reason to swap in my opinion is if you are looking to change the powerband for a specific application, like trying to cross the traps @ a higher RPM in third to increase your average power to the ground during a run.
2005gxp
11-08-2010, 09:24 PM
ahh, thought we had a 3.69 stock gear. so best to stay stock then. when i order my 15/16ths drive chain i will order it for a 3.29 gear?
evil5.3
11-10-2010, 07:12 AM
i pretty sure the gtp comp g were the only car with the 3.69 but not positive
DieselPump
11-10-2010, 08:10 AM
the comp g was the only car that came with the 3.29 gears.
GTP's and GXP's all came with 2.93 gears.
2005gxp
11-10-2010, 01:50 PM
so whats the best gear for my car?
supercatxr7
11-10-2010, 04:34 PM
I have 3.29's GM 1" racing chain set up.
2005gxp
11-10-2010, 04:46 PM
what would you recommend? im getting a 15/16ths chain
CenTexSS
11-10-2010, 10:44 PM
His 11.01 @ 126 would make me think the 3.29's are good!!!
I don't think anyone who has done the 3.29's have regretted it though.
blakss
11-11-2010, 01:19 AM
lucky Muthashutyomouf !:devil:
blakss
11-11-2010, 01:21 AM
you need to completely rebuild to swap gears and chain? and tuning correct?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
