Cam02ss
11-08-2010, 09:51 PM
Finally took the car down to Cecil on 10/29 to make some passes with the new solid roller setup. Previous best on motor with the hyd roller had been a 10.6 @ 127. After a couple passes not hooking up off the trans brake, we made some suspension adjustments and ran a 10.1 (hit the rev limiter) leaving slightly above idle. Next pass, left off the foot brake again just above idle and ran 9.86 @ 137 mph.
60'- 1.468
1/8- 6.303
MPH- 110.29
1/4- 9.868
MPH- 137.88
This run was NA, car is built for spray. Setup is as follows-
408 iron block, 13.6:1 cr, TEA/TF 235 heads, Cammotion solid roller cam, Manton pushrods, Crower HD lifters, Accufab Dominater TB, FAB9 rear 4.30 gears. Wilson Pro Flow plate system 175-300 adjustable.
60'- 1.468
1/8- 6.303
MPH- 110.29
1/4- 9.868
MPH- 137.88
