Reccommendations for tuning on a dyno
I'm going to have a little time on a dyno this weekend to tweak my tune.
I'll be using the dyno's WB to tweak my A/F and will be working on my spark tables also. What kind of things should I log? Does anyone have a .cfg file they use on the dyno?
Just looking for a little direction as far as procedures/what to expect so I can make the most of my time on the rollers. I poked around a little on the HPT forums, but wanted to get opinions from the masters here also.
Thanks in advance.
Thanks in advance.
1 Post
Personally, I never use a dyno wideband stuck in the tail pipe... I put mine in the header in place of a stock front one (unless they have an extra bung installed)... much more accurate than sticking it in the pipe - especially at idle and part throttle, but even at WOT...
As far as logging, I log commanded AFR, wideband AFR, spark, knock, MAF frequency, MAP, TPS, RPM, INJDC, coolant temp, intake air temp...
Thanks for the reply. I have an extra bung instilled in the driver's side collector that has an LC-1 installed, but I'm not using it yet since I don't have the Pro cable. I have catted mids, so would that extra bung be the best to use?
I've read so many threads in the past week that its starting to make my head spin. I'm running SD, by the way.
1 Post
I would put the wideband in a bung in front of the cats...
Thanks for the tip, I've made that mistake before. In this case, though, the knock map has the max value button (up arrow) selected not average so it shows the highest value in each cell. But you're right, if average is on the 0s can really distort the data unless you do like you said.
