push rod length checking write up with hydraulic lifters?
This is from Shane at Thunder Racing. I have used his method before and it worked great each time.
FWIW, EVERY cam install I have done using the LS7 lifter with a cam with greater than .600" lift (read smaller base circle) AND stock heads w/GM MLS gaskets has taken 7.425" pushrods for ~.050"-.060" preload. We measure lifter preload on each and every cam install we do. I have never had a lifter failure nor do we end up with the dreaded "sewing machine" noise.
Its very simple, If you change ANY of the following:
valve sizes, valve job, head milling, thinner/thicker head gaskets, decked block, cam with an altered base circle, etc... YOU MUST CHECK FOR PROPER PUSHROD LENGTH.
I have helped countless numbers of individuals with this process over the phone, via email, and PM's. I've posted the process on at least 3 occasions.
Here it is again in a nutshell:
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
If you are not familiar with the EO/IC method for determining valve events in a 4 stroke engine, its very simple:
For a given cylinder as the Exhaust valve is Opening, the intake lifter will be on the base circle of the cam and lash/preload should be checked for that intake valve.
For a given cylinder as the Intake valve is Closing, the exhaust lifter will be on the base circle of the cam and lash/preload should be checked for that exhaust valve.
THIS METHOD ALWAYS WORKS!!!
I hope this helps someone. I have explained it so many times I think I do it in my sleep!!!
Shane
Shane
From what I gather stock ls1 lifters should be between .020 and .060 so most say to use .050 preload.
Thats what I added to my measurement for my rods after checking them with a push rod length checker.
Thanks for the info guys!
He is saying that a standard rocker arm bolt with 1 turn adds a preload of .047. If you torque from 1/4 to 3/4 of a turn and get a click with your rod length checker then you can add what a preload to that length of your desire. But if you check around the range is .020 to .060 that the stock ls1 lifters can handle.
Thanks darkman for your attempted snarky reply but you are apparently as your name suggests, in the dark.
I love how you talk **** about the poster above you then ramble incoherent incomplete sentences directly following. Could you fail at posting any harder?
