Convertible subframe install... remove stock SFC?
Old 02-03-2004, 01:05 AM
Mevin's Avatar
Default Convertible subframe install... remove stock SFC?
I'm looking to upgrade my convertible '98 Trans Am to Kenny Brown double diamond subframe connectors... I'm aware that the car already has stock subframe connectors on it -- are these to be removed when installing the KBDD's? If so, is this an easy thing to do?
Thanks.........
-kevin
Old 02-03-2004, 05:43 AM
mcflyz28's Avatar
Look again there ain't nothing there.
Old 02-03-2004, 08:56 AM
Moderator
jimmyblue's Avatar
The "connectors" are really just additional sheet metal
that makes a continuous "rail" front-back. You wouldn't
want to try removing it. Just add to it if you want.
Old 02-03-2004, 11:23 AM
WayneSS01's Avatar
Nothing is removed in the installion. Just fit them up and weld. It has been suggested the car be on a drive-on lift so the chassis is loaded for installation. I have pics of them installed on the last page of my site.
Old 02-03-2004, 07:04 PM
Mevin's Avatar
OK great, thanks guys.
-kevin
