IAT sensor?
Old 11-09-2010, 08:39 PM
1989k1500's Avatar
Default IAT sensor?
Not sure this is the place to post this but....
Does anyone know if this IAT sensor is the same plug as a F body IAT sensor?
http://www.summitracing.com/parts/FST-307004/
Im doing a harness for a Gen III swap starting with a truck harness and need something for an IAT sensor since the truck wont have a MAF.
So I was thinking of getting that sensor and a IAT sensor plug from Current Performance. But I dont want to spend 19 dollars to find out they dont work together.
Thanks in advance
Old 11-09-2010, 08:46 PM
LS1MCSS's Avatar
An f-body sensor, at Auto Zone is $12. Get that and a plug and then you know you have something that will work together.
Old 11-09-2010, 08:53 PM
1989k1500's Avatar
How do they attach to the air box?
Old 11-10-2010, 07:04 PM
oange ss's Avatar
thru a rubber grommet, if you need one for boost that Summit one looks close, but withut seein the connector internals it's hard to tell
Old 11-10-2010, 07:53 PM
LS1MCSS's Avatar
The rubber grommet just pushes into a hole in the airbox and then the sensor pushes into it.
