99 camaro z28 mint
99 camaro z28 mint
this is my 1st post on here! i have wanted a foxbody or a z28 or ss for a while. selling my f150 4x4 right now. but i just found this hell of a deal up in new york. i live in fl is flew up to see it drive it and ended up buying it. here is the stats.
let me know wat yall think. i would greatly appreciate all the advice and comments.
The car has 48,900 miles on it, and is in mint condition. See details below:
ENGINE
LS1 Forged Bottom End
Forged Connecting Rods
Forged Pistons With HTC Coating
Plasma-Moly Piston Rings
Forged Crankshaft
New Rod Bearings and Main Bearings
LS1 CNC Ported Cylinder Heads
SLP Oil Pump
Double Roller Timing Chain
ARP Wave-Loc Head Stud and Nut Kit
Upgraded Valve Springs
Custom Ground Camshaft, For Forced Induction/Nitrous Setup
Compression Ratio 9:1:1
NGK TR-6 Spark Plugs
TRANSMISSION
4L60E
3500 Stall Converter
Performance Clutches and Steels
Custom Valve Body Work
Boost Valve
Hardened Sun Shell
Trans Go Shift Kit
FUEL SYSTEM
Walboro 255 In Tank Pump
SUSPENSION AND REAR END
Moser 12 Bolt Rear End
3:73 Gear Ratio
Energy Suspension Mount Kit
BMR Lower Control Arms
BMR Weld In Subframe Connectors. (Run almost the entire length of rocker panels)
Carbon Fiber Drive Shaft
BMR Driveshaft Loop
Flow Tech Turbo Exhaust, 4in Outlet
EXTERIOR
Camaro SS Hood
Camaro SS Spoiler
Center Of Hood Painted Black
T-Tops
1999 TRANSAM unpolished 16 x 9 rims with all tires sized 245/40/16, front are worn and rear are brand new
INTERIOR
Corbeau Racing Seats
5 Point Harness Kit
Rear Seat Delete Kit (Not Hacked Up, I Do Not Have Rear Seats)
Factory Interior Remains
here is some crappy cell phone pics but ill have way better pics up later.
ENGINE
Forged Crankshaft
SLP Oil Pump
TRANSMISSION
4L60E
Boost Valve
Hardened Sun Shell
Trans Go Shift Kit
FUEL SYSTEM
3:73 Gear Ratio
BMR Driveshaft Loop
EXTERIOR
Camaro SS Hood
Camaro SS Spoiler
T-Tops
INTERIOR
5 Point Harness Kit
LS1Tech Administrator
Received 1,488 Likes
Personally, I think it looks great other than the Firebird wheels. I'd change them to any one of several 17x9 or 17x9.5" wheels on the market.
i saw the paperwork when i was up there and forgot to get them when the transaction was made. im having him mail it down.
8500 bucks sounds like a steal..Nice car.
thank you. i looked up and down 4 cars and this one stuck out like a sore thumb. idk how someone didnt scoop it up be4 me.
ill get a vid up soon. prob in a couple weeks. i dont wanna run her wide open yet because im not used to the power and the handling. but i deff will.
he took real good care of it. and so will i.
