Engine Cuts Out
Old 11-09-2010, 11:37 PM
duffy_3554's Avatar
Default Engine Cuts Out
I am having this problem with my z28 i just bought it is all stock under the hood and everytime i get into it in second or above it cuts out or losses power right at 2400rpm almost exactly the same point everytime. If you run it wide open it will not do it. i changed the throttle position sensor and cleaned all the connections and it still does it. Any help
