dual clutch opinions?
I'm building a 402 inch stroker with LS3 heads, LS3 intake, etc. Horsepower is expected to be at or slightly above 500RWHP. Maybe a 150 shot down the road, maybe not.
I'll visit the track, but this will be mostly street driven, so I want good drivability, easy engagement, etc. Of course, I also want it to survive my trips to the track.
I think that for the sake of good street manners, I want to go with a dual-disk style setup. I've had my eye mostly on the Ram and the McLeod clutches, mainly because those are what I seem to see the most of. I would really like to stay at or below $1k (including new flywheel) unless there's a very compelling reason to go beyond that. Anybody have opinions and/or personal experiences to share?
I have a McLeod RST and went with a twin for the exact reasons you mentioned. I do make less power than you will and no nitrous either but I left myself plenty of room if I want to up the power level later on. Zero chatter, easy clutch pedal, and holds perfectly so far although no track trips yet. I bought the billet steel flywheel with it and want to say it came out to around $1100 or so.
My OZ700 bit the dust finally (15k miles and 2 clutch discs later). I just bought a Mcleod RXT, making 778rwhp on the bottle and doing 5k+ dumps at the track. I street drive about 6k a year and do Standing Mile racing, so I hope the choice was the right one. Havent seen any complaints anywhere on the RXT or RST clutches.
If memory serves you have an LS motor and T56 installed correct? If so, our SC09SST Super-Twin would be a great option for an LS based application with this output. It is rated to handle 900lb.-ft at the crank and will be easily daily drivable. It is also rebuildable too which means that you save on cost when the time comes for another unit. Let me know if you have any further questions. Thanks!
The one I have is the T1SR-G01.
It has one puck-type disk and one full face organic and is rated at 1150ft. lbs.
They offer an entire range from 800-1500 ft.lbs depending on what you are looking for.
If your planning on upping the HP like you stated running nitrous on top. I might look at running a twin. Im running a Fidanza Carbon Twin setup and its in the $ range. Drives like stock pedal. A little more aggressive when cold in morning, but smoothes right out after warmup. Pedal is very consistant. Slips well as I use it as my DD, but grabs like hell and kinda shocks the rear when launching or a slip to dump situation. Clutch is controlled by stock master and slave cylinder a functions fine. But I will be upgrading to a Tick master. I'm really happy I spent the extra $$ and so far have been happy with my decision. Hope it helps but after 3 clutches in a little over 1 year nothing is overkill when it drives like stock but can handle the fury when I unleash it. Do it right the first time to go twin.
Wow I remember you from WAY back in the day on thirdgen.org. I was 89ROC on there. Honestly, I would just stick with a single disc. I offer a Stage 3 thats good for 700hp, and is very streetable. Its a full 12in disc/pp setup. Check out the websites in my sig.
Your own description says that "it works like an on/off switch". That really doesn't sound like the kind of drivability that I'm looking for. Any plans to develop an organic twin disk setup?
The Stage 2 is a dual friction setup that drives just about like stock, maybe 15-20% more pedal pressure. This one is good for 600hp, so it will work fine for your 402. $409 for the basic kit, or $759 if you want the lightweight billet flywheel and new slave cylinder. Free shipping and free remote bleeder with this.
Anyway, just wanted to let you know about this before you shell out $1200+ for a twin disc.
I am currently working on a twin disc setup, and it should be ready by Spring. If all goes well, then I should have a WAY lower price than any other company. I still think its overkill for you though.
Thanks for the feedback. The twin disk may be overkill now, but I always like to have room for expansion. I'm not buying right away, so maybe I'll wait and see what your twin disk looks like in the spring.
I'm concerned that I may be pushing the limits of the stage 2... I'm shooting for 500+ to the wheels, so I'm going to be right at or above 600 at the flywheel.
I have another question though... what's the longevity like on a twin disk compared to a single disk? Does the additional surface area of the twin disk translate into better (i.e. longer) wear? It seems that a lot of people on here get very low mileage out of their clutches, though I'm guessing that they are a lot harder on their stuff than I'll likely be, but if the twin disk is going to last longer, that seems like it could help offset the initial cost to an extent.
If you want to stay with a single and need great drivability and capacity then our Stage 3+ would be a fantastic option. Please let me know if you have any further questions. Thanks,
LS7 Clutch Special Limited Time...Monster Clutches $200 OFF Holiday Sale!!!
Hey guys, we just received our shipment of Brand New LS7 Clutch Kits, they are instock ready to ship the same day you order...We also have instock all the Accessories to complete your clutch install ...
LS7 Clutch Kits....$425
Includeds Flywheel, Disc, Pressure Plate & Alignment Tool...
LS6 Clutch Kits....$399
Hey guys, its that time of year again when we go crazy and drop prices to the lowest they have ever been!!!
**Monster Clutch Super Holiday Special Sale**
These prices reflect the $200 discount..
Level 1-425hp/tq $549 shipped to you!!
Level 2-525hp/tq $549 shipped to you!!
Level 3-700hp/tq $579 shipped to you!!
Level 4-775hp/tq $579 shipped to you!!
Level 5-825hp/tq $779 shipped to you!!
Level 6-900hp/tq $779 shipped to you!!
Light Weight Steel Billet Flywheel 18lbs $50 extra
Monster Clutches 11" Race Clutches are $100 OFF
Extra Special Deals on What you need...!!!
Please note:: Our New Clutch Remote Speed-Bleeder kits are specificly made for F-body's & GTO's...
ECPC's NEW F-body & GTO Remote Clutch (one-man) Speed-Bleeder Kit $45.99 w/Clutch Purchase
A 40" Stainless Braided Clear Teflon Coated Line!!
ECPC's Remote Clutch Bleeder Protector $19.99 w/Bleeder Kit Purchase
2000 deg Thermo Heat Sleeve for your Bleeder Line
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
GM Flywheel & Pressure Plate Bolts $19.99 w/Clutch Purchase
Clutch Accessories Specials w/clutch purchase....
GM F-body Slave $69.99
GTO Clutch Slave $79.99
GM HD Throw-out Bearings $39.99
LS1 & LS6 HD Pilot Bearing $12.99
LS2,3,7 HD Pilot Bearings $18.99
High-Performance Clutch Fluids
GM DOT4 Clutch & Brake Fluid 8.45oz(250ml) $12.99
Motul RBF600 Clutch & Brake Fluid 16.90oz(500ml) $19.99
We sell Monster, RPS, our LS9zr6 and of course OEM LS6 & LS7 clutches...We average about 250 clutches per year...
Call Mike Yeager to place your order Mon-Sat 9am-8pm est...Sun 1pm-7pm est...
Thanks for your interest..
We accept Visa, MC, Disc, Amex & Paypal..!!!
