what manifolds do you guys use for a turbo notch
Old 11-13-2010, 07:52 AM
crazygn's Avatar
Default what manifolds do you guys use for a turbo notch
What do you guys use on the ls1 engine, trucks maybe, will c6 manifolds work. My cam only is going turbo over the winter.
Old 11-13-2010, 10:22 AM
71ANTICARB's Avatar
I think most guys are using truck manifold.
Old 11-13-2010, 01:47 PM
kornerz's Avatar
i have a a pair of manifolds and crossover i can sell you. i welded it up and ended up keeping it na. the pass side is a drivers side truck mani, and the driver side is a pass. f body manifold. i didnt use the truck manifold on the driver side because i wanted to keep the alternator mounted low. let me know.
Old 11-13-2010, 01:48 PM
kornerz's Avatar
its all welded up now.
Old 11-13-2010, 04:18 PM
crazygn's Avatar
How much , not sure i want the turbo mounted in the fender. What are you doing with the air filter and maf
Old 11-14-2010, 12:03 AM
kornerz's Avatar
no maf. speed density is the way to go. i was just going to put a screen on the turbo.
ill take 100 plus shipping
