Clutch install help ASAP
Old 11-13-2010, 01:07 PM
Camvill's Avatar
Default Clutch install help ASAP
i have my car on a lift and the guy who sold me the pressure plate and disk said i needed to do something with the dowel pins in order for it to fit i dont remember what though plzzzzz help
Old 11-13-2010, 04:12 PM
dgcustomz's Avatar
remove the dowel pins, they are not necessary. Align the clutch with the alignment tool and you will be good to go. If you are the guy I think you are, then you kept your stock flywheel and had it resurfaced. You need to pull the dowel pins out of your stock flywheel and you should be good.
Old 11-13-2010, 09:01 PM
Camvill's Avatar
dont they need to be in for the balance?
Old 11-13-2010, 11:02 PM
RedRallyeZ's Avatar
nope, they were only for helping you align the pressure plate while putting the bolts in. i didnt put them in on mine
