How do you ID Jet Hots?
I purchased a set of new never installed Jet-Hot headers. I was told they were for an 00-02 LS1. Are their any changes between the years 98-02. They have one air tube connection on each header.
Thanks
Thanks
SN95 Director
ya i did my own install. just basic hand tools, jack stands, and jack were all that was needed. had the rear on ramps and the front jacked up with my jack on a piece of 4x4 wood for more clearance. if you have the time and tools i say go for it. can easily be done in a weekend and you save 350 bucks.
SN95 Director
ya, at least give it an attempt. the hardest part for me was removing the old setup. i had to grind down the block tab on my engine because i couldnt remove the steering shaft. the passenger side slide in pretty well. if you dont have anyone to help you, use an extra set of jack stands to hold the header up while you bolt them in from the top, makes it easier.
