12 Second Club - New best 12.89 @ 117
ponyhater27
11-14-2010, 05:11 PM
Second time out to the track and a new best.
60' 2.232
330 5.87
1/8 8.62
MPH 91.30
1000 10.95
1/4 12.89
MPH 117.12
It got a good MPH and pulls so hard on the top end. If I could just uncrap the launch surely it will go 11's. I was just on a wore out Sumitomo 315 so maybe with some drag radials and a good launch the ET will come down.
blk/slvr02ss
11-14-2010, 05:26 PM
That MPH is great but your 60ft can be alot better w/ drag radials and should hit 11's no problem !!!!!!!
Fast T
11-14-2010, 06:52 PM
I would try puting a drag radial on it, and watch what it do .you mite be surprise.
ponyhater27
11-15-2010, 01:28 AM
Yup Im planning on getting drag radials next year for sure. I just can't decide if I want to buy drag wheels/tires or just buy some 315 drag radials for the ZR1's. I was spinning on the 1-2 shift quite a bit and I had to resort to short shifting it so it wouldn't spin. So drag radials will for sure help!
gunit
11-15-2010, 10:33 PM
Nice run w/ no traction.
You need a 9" and some DR's asap.
lemons12
11-15-2010, 10:46 PM
Every .1 in the 60' is about .2 off your ET.
I would get an extra set of rims and put slicks on them.. Only way to get a 6 speed to consistently hook.
ponyhater27
11-17-2010, 08:06 PM
Thanks Grant! Do you miss it any? I really want to get a 9" bad! A 9", Some Weld RTS, Drag Radials or Slicks, and a two step! It should really get up and go then!
lemons12
11-17-2010, 08:18 PM
Pony.. how about some pro stars.. near brand new tires on front and the rears are hoosier slicks.. tons of life, about 12 1/8 mile passes and around 75 street miles, they are stored correctly in doors while I use my rpms while normal driving.
Only reason for selling is buying some ccw drag pack.
You are in ky so we might get away from shipping.
I have ligaments center caps spacers and all..
2001-CamaroSS-LS1
11-18-2010, 06:07 PM
are you loading it up at all?
ponyhater27
11-18-2010, 10:53 PM
lemons I'm wanting to go with a wheel where I don't have to grind calipers. I know I can use the spacers with the prostars but I've already got my heart set on the RTS.
I am loading it up a little. This past time for some reason I wasnt paying much attention to exactly what RPMs but I know it was around 3K. Then slipping the clutch out.
CamaroZ28_LS1
11-19-2010, 11:38 AM
I am guessing you spun tires every time you shifted because I ran a horrid 12.6 @ 114mph on DR's with a 2.1 60 foot time, bogged off the launch lol.
ponyhater27
11-19-2010, 09:35 PM
I know for fact that is was spun on 1-2. The other shifts I can't remember if it spun or not. I don't remember feeling it spin but it may have. I do remember the car bogging a little off the line. I was slipping the clutch pretty good. Instead of the driver mod. I need the more seat time mod.
CamaroZ28_LS1
11-20-2010, 01:25 AM
still a great trap speed easily for 11's! I see some DR's and easy 11's with good shift times in your future lol.
Joshiedoom
11-20-2010, 05:19 AM
http://www.youtube.com/watch?v=oeR0PwzrZCo
found it on youtube :)
ponyhater27
11-20-2010, 10:09 AM
That particular pass was
60' 2.47 lol
330 6.11
1/8 8.86
MPH 91.47
1000 11.20
1/4 13.142
MPH 116.84
What a turd!
In the future I hope to see some 11's I would be happy with this setup if it went 11.5 but we shall see.
gunit
11-20-2010, 11:11 PM
I do miss it, but I'm glad you've got it running and have kept a hold of it.
Good luck getting that thing to hook next season, hopefully see that 11sec pass.
Fast T
11-23-2010, 10:27 AM
you have dam good mph, I believe if you put a good tire on it ,it would lay down a dam good number four you.
