Will i have to flycut
i have an ms4 and will be getting those heads. i have been told u dont have to. i sure hope not. i would definately like to hear from someone with that combo and what kind of numbers theyve made also
LS1Tech Premium Sponsor
That combo actually has better (more) valve drop than your stock cylinder heads did and we have tested them with that cam many times! So yes, we can tell you, so long as the parts are installed correctly, you will have ample piston to valve clearance on that combo
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
