Generation IV Internal Engine - 408 build
View Full Version : 408 build
02sslayer
11-15-2010, 05:16 PM
im planning on doing a 408 build for my 02 camaro ss in the next couple years. i want 550 to 600rwhp with this motor n/a. what would be the best h/c choice to get me there? i was thinking AFR 225cc or 235cc heads and a 25x/25x cam?
02sslayer
11-17-2010, 02:46 AM
any thoughts on this guys? i think id actually be good with 525 to 550whp.
Jim85IROC
11-17-2010, 10:44 AM
600RWHP out of a naturally aspirated 408 is a tall order and will likely require a premium set of heads & intake along with a fairly large cam.
If you step down closer to the 525 number you mentioned, then you have a lot more options. Almost anything will get you there. Since I'm on a tight budget, my goals for my 402 (same thing, less overbore) are stock LS3 heads, stock LS3 intake, and a mild-ish cam. Not only does the inexpensive price of the LS3 head appeal to me, but the fact that it works so well with a small cam really appeals to me. I want a very street friendly car that's easy to drive but still makes 500+ at the wheels, and I think that the LS3 heads will give me that.
Since you're not in a hurry, rather than decide on heads right now, just start doing homework, and give the aftermarket some time to start pushing some square port offerings. I suspect that you'll be seeing a lot of them over the next year, and I think that they are going to be very good at providing even more of what the stock LS3s offer... big power with mild cams (i.e. good street manners).
02sslayer
11-17-2010, 04:33 PM
im starting my home work now, i went with a h/c package for my ls1 and i wish i would have waited and just done a stroker motor like a 402 or 408. im thinking afr will be the heads to go with and i have no idea about a cam. i will go with a custom grind for sure. i dont see alot of shelf cams for 400+ci motors. custom is the way to go anyhow. i would of course go with a fast 102 setup and 100mm maf.
WKMCD
11-17-2010, 05:08 PM
Here's a good sticky with many 402,403 and 408's. Build info and results.
Happy reading...
http://www.ls1tech.com/forums/dynamometer-results-comparisons/816128-408-results-part-ii.html
JustAnotherLS2
11-18-2010, 10:22 AM
600 will be tough....525 should be no problem. L92s will definitly do the trick for the 525.
02sslayer
11-19-2010, 01:46 AM
i may have decided to go with a lsx454 instead, it only seems to be a couple grand more, and thats about as good as it gets for me. thats been my dream motor for a long time.
