Drag Racing Tech
quest for elevens
Old 02-03-2004, 07:04 PM
okie00ls1's Avatar
Default quest for elevens
what is needed to run 11's with stock internal's m6 and full weight car. Right now all I have done is true duals, lid, free mods and no sway bar, stage 3 clutch is on the way and have some bfg dr in garage. best time in sig. need help before I put it on the juice.
Old 02-03-2004, 07:39 PM
Administrator
unit213's Avatar
A $500 nitrous kit.
Old 02-03-2004, 07:41 PM
BlueSix's Avatar
A 12 bolt might help.
Old 02-03-2004, 10:33 PM
Revelation222's Avatar
Ported TB, ASP Underdrive Pulley, Electric water pump, short belt, LS6 intake (Unless you have one allready) maybe the LSX intake? Havent seen any track times with it yet, and 410 gears, or if money is no object get a Moser 9". Still dont see you hitting 11's but that should help get you close.
Old 02-04-2004, 08:46 AM
taqwache's Avatar
put some 4.10s in it, headers, LS6 intake and launch out off the rev limiter. i cant guarenty you will not break the axle but you might get in one run or so. what are you running right now.
Old 02-04-2004, 09:51 AM
Motorboater
SilverGhost's Avatar
full weight always makes things more difficult, taking some weight out of the car would help alot.
i say put a gear in it, but def try to afford a 12 bolt or 9 inch, 4.10 gear or maybe bigger even.
if you don't have longtubes those are pretty much a must have on these cars IMO.
Old 02-04-2004, 08:06 PM
okie00ls1's Avatar
right now I am running 12.7's at 111mph and that is pretty much stock on street tires so I know bfg dr will help out but I was what else i might need to come very close.
Old 02-04-2004, 08:28 PM
racer88's Avatar
Headers and a slick launching around 5K will get you a 12.3 or lower. A buddy's Dads Z ran 12.1 with just bolt ons.
Took me a small cam to hit 11's with headers and gears on drag radials full weight.
Old 02-05-2004, 10:02 PM
SMOKIN01TA's Avatar
with nittos 4.10s headers intake clutch and some lca's i ran 12.2x@114 with 1.8 60' ill get 11's with some slicks and some weight removal. or just get a short belt.
