Catch can Question
Catch can Question
http://www.tuningdepot.com/ebay/imag...atch-3red2.jpg
why is there three connections on here when you only need 2? will this work for a camaro? I would assume that the 2 equal size tis would be the ones to use, and just cap off the large one?
That design is kinda wierd. You always want the nipples to be the highest point on the can, because once that can starts filling up, you don't want to start sucking liquid back in the engine....
I'm not sure what I would suggest with that one..
I use a greddy catch can and it works great.
Tommy
Tommy
Best price I found was here:
http://www.greddy.com/products/produ...productidx=136
I'm going to buy one within 2 months; I've got the vertical PCV mod right now but still sucking oil in with a TR224-112 cam and heads. I plan on connecting after the PCV to the can, then to the intake manifold.
I've been researching for 2 days; does AFTER the PCV valve make the most sense?
I simply wedged it in the spot you see it in. I wrapped the bottom in a piece of rubber (I cut a large diameter rubber hose in half, kinda like a fernco bellow piece), so it would not rattle or move around at all.
Tommy
Tommy
No, mine is coming from the valley only (LS6 PCV). However I have my air pump acting as a small electric vacuum pump at WOT which pulls from the driver's side, but that's a whole other story
Tommy
Tommy
"However I have my air pump acting as a small electric vacuum pump at WOT which pulls from the driver's side, but that's a whole other story "
Sounds interesting - I no longer have AIR but still have the components. What is the mod? If this is thread drift, PM me if possible.
