85 z28 wanting to do a 5.3 carbed swap??
Old 11-17-2010, 12:45 PM
Car-less Chris's Avatar
Default 85 z28 wanting to do a 5.3 carbed swap??
ive got a buddy who has a 85' z28 roller in good shape and access to a free 5.3 out of a 01 truck..he wants to go the easiest route and go carbed..ive seen quite a few threads and done a few searches but nothing to really help answer my questions..here they are as follow..thanks in advance for all the help guys!!
what all parts will i need to make it work?? car is strictly a race car..no p/s, no a/c..etc..
what headers are the best bang for the buck??
which intake/ignition is better??
can you use factory k-member??
Old 11-17-2010, 02:10 PM
Jim85IROC's Avatar
You only have one header option: Hawks.
Intake: For a stock 5.3, I'd say the Edelbrock Performer is your only real option. As for ignition, that's the MSD. It's more capable than the edelbrock.
Factory K-member: Yes. I'd ditch the truck oil pan though, or you're going to tear it off on the first speed bump you come to.
There's a ton of info in the "engine swap" forum on thirdgen.org. I'd check it out.
Old 11-17-2010, 02:50 PM
thanks..were going with the victor jr..an msd ignition..cause more than likely he will go 6.0 after its running..were using the trans dapt motor mounts..
Old 11-17-2010, 03:57 PM
1A Dan's Avatar
make sure you get the 1" set back ones - you'll require a notch in the kmember if you use the standard ones
Old 11-17-2010, 04:26 PM
damn the headers are expensive!!
Old 11-17-2010, 05:15 PM
xvictimx26's Avatar
Ya they are I just left the cast manifolds on in my '84 t/a good enough for me as all I have is is a stock 5.3
Old 11-18-2010, 12:08 PM
green94z's Avatar
kool project. Swaps like these can get expensive, good luck with the build.
Quick Reply: 85 z28 wanting to do a 5.3 carbed swap??
