Part Interchangeability (96 to 00-02)
1 Post
I am thinking about getting a 00-02 WS6... and if i am... I was wondering if the parts I have on my car I can swap out to my new 00-02 car.
The Koni 4/4 and strano spring setup, the UMI adj t/a and relocation xmember, the UMI adj PHB, and the GMMG... anyone have any info??? Thanks
'Bird Director
The UMI Adjustable Torque Arm & Panhard Bar will interchange.
The floor pan on '93-'97 & '98-'02 were slightly different, so the relocation mount may not be the same. I know the automatic transmission mounts are different between the two. If you're using the "trans-mount" torque arm with the relocation bracket, then your bracket probably mounts in place of the factory transmission mount. If that's the case, then you might wanna contact UMI to be 100% sure.
Hope that helps!
Ryan
