Paint & Body Work - can I remove the triangle piece by the sail panel ????
Raven97
11-20-2010, 11:22 AM
I am about to start prepping my bird for a new paint job and I was wondering if the little triangle by the sail panel is removable. It sits really close to the quarter panel so in order to sand it and paint it right I need to take off the triangle. I tugged on it but it seems glued on or something. What gives?
67goatman455
11-20-2010, 06:41 PM
it is held on by a large piece of double sided tape. i always use a putty knife (metal spreader) to cut the tape behind it.
Raven97
11-20-2010, 09:49 PM
Thanks I'll give that a try ;)
but if I fubar them up is there a place to get new ones?
toplessHO
11-21-2010, 08:02 AM
you can cut the tape with nylon string and a sawing motion but if not careful you can cut thru the plastic as well.
67goatman455
11-21-2010, 10:20 AM
just dont put the plastic at too severe of an angle and it wont snap. but if you do, just go to a junkyard and pull some off
67goatman455
11-21-2010, 10:23 AM
or you can do what i just did, i painted my buddys quarter panel recently and stuck an allen wrench behind the part that touches the quarter panel. that pulled it far enough away for my clear to be dusted underneath
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
