Drag Racing Results - ls1 cam heads stall 12.1???
View Full Version : ls1 cam heads stall 12.1???
anheuserbusch08
11-20-2010, 07:12 PM
i have a 98 trans am stock bottom end stock intake stock fuel injectors, 3200 stall 3:73 gears 224/230 581 588 114 lsa 317 heads ported and polished by me, heads milled.060 and the best i got it to last night was 12.11 @ 113.45 is it running good or should i upgrade to a bigger cam? i want to hit 11s all motor guys please help thanks!!!!!
anheuserbusch08
11-20-2010, 07:34 PM
anyone?
N2RACINGLS1's
11-20-2010, 08:27 PM
Well not sure where you are located or what the DA was but I ran 11.94 ET with a completely stock engine internally with just headers, stall, 3.70 gears at 3,665 lbs.
I hope this helps!
N2
anheuserbusch08
11-20-2010, 08:35 PM
I hope this helps!
N2
im located in houston tx :)
demarco313
11-20-2010, 08:46 PM
That STOCK INTAKE is really killing you and is a SUPER RESTRICTION on a head and cam car! You still have the ls1 intake! Upgrade that to at least a ls6 intake (ported ls6 would be better) and ported throttle body. If you really want the best results and the most HP go with a ported FAST intake and a nick williams throttle body. You will see a drastic difference!!!! Make sure when you swap your intake and TB you get your car retuned for the best results! Goodluck :) Also do you have an aftermarket CAI or stock?
anheuserbusch08
11-20-2010, 09:58 PM
its a drop-in k&n filter with a slp cover
demarco313
11-20-2010, 10:32 PM
o ok. thats cool. Get that crappy ls1 intake and stock TB off pronto and retune and you will see a BIG BIG increase!! :D
anheuserbusch08
well what should i go with?????? please help me thanks :D
demarco313
11-20-2010, 10:46 PM
Depends on your budget? If your on a budget you can buy a nice ported ls6 intake and ported TB combo that ive seen sold on here for about $350 min to about $400 max.
If your not on a budget I would say a ported FAST 90 or 92 with a Nick Williams throttle body. Another suggestion would be to go with the new FAST 102 intake but there seems to be mixed reviews on it for a stock 346 CI motor. Some ppl say its overkill some ppl like it. You would be good with any of the intakes mentioned though and it will be a a significant increase from that stock ls1 intake/TB. Your leaving alot of HP/TQ on the table with that ls1 intake/TB man.
anheuserbusch08
11-20-2010, 10:55 PM
DAMN NICE TO KNOW how will my ET times vary?
Top Fuel
11-21-2010, 12:46 AM
what was your 60'? that mph is good for at least 11.70's
anheuserbusch08
11-21-2010, 01:44 AM
1.78 on mt street radial 2's
TrikeMike
11-21-2010, 02:04 AM
Still even with the stock intake something is not right. The car is down on power or something. How much experience do you have with porting? A bad port job can hurt power. My car goes 12.2 @ 110 on stock LS1 intake and stock cam and stock 853s.
anheuserbusch08
11-21-2010, 02:11 AM
not much but i did feel the difference over stock 241 heads. it may just be the heads though i didnt polish them as much as i should have.
demarco313
11-21-2010, 02:20 AM
This could be true a bad port job could hurt power although we dont know the DA you ran in vs his. He could be running in really bad DA which will result in a much worse et and trap speed. There are head and cam full bolt ons, ls6 intake, P&P TB, gears and stalled cars that trap only around 114-116 (possibly bad DA) so considering OP has the stock ls1 intake/ TB trapping almost 114 isnt bad at all.
OP what HP/TQ numbers did it make on the dyno?
anheuserbusch08
11-21-2010, 02:27 AM
This could be true although we dont know the DA you ran in vs his. He could be running in really bad DA which will result in a much lower low et and trap speed. There are head and cam full bolt ons, ls6 intake, gears and stalled cars that trap only around 114 (possibly bad DA) so considering OP has the stock ls1 intake/ TB thats not bad at all.
it has never been dynoed. but changing from the previous tuner to the one i have now (flaco) i gained 2-3 mph
Top Fuel
11-21-2010, 02:42 AM
work on the 60' for sure. what size MT radials? what brand stall? what other bolt ons do u have? what do you have for suspension?
demarco313
11-21-2010, 02:45 AM
Aw man.. Car still has alot left in it. Any head and cam car needs to be dynotuned for maximum results. The more power you add the more that ls1 intake becomes more of a restriction. On just a stock car (98-00) ppl swap over to the ls6 intake a dyno it and see nice gains so you will see really good gains with a heads and cam car rather you decide to get a ls6 or FAST intake. Add a ported intake and ported TB then get it dynotuned and it will definitely be a night and day difference!
anheuserbusch08
11-21-2010, 02:58 AM
sounds like a deal i also have a 370 s10 with ls1 intake i should upgrade it as well.
anheuserbusch08
11-21-2010, 03:01 AM
pi 3400 i sent to get reworked on local, torque thrust 2's 17 inch rears on mickey thompson street radial 2's best time off of them was a 1.78 60 ft :D
anheuserbusch08
11-22-2010, 07:44 PM
ttt! more help please!
anheuserbusch08
11-24-2010, 06:56 PM
anyone else???? point me in the right direction thanks!
Intercooler2
11-25-2010, 09:51 AM
About? No it isn't up to par. Intakes have been suggested. Work through it
anheuserbusch08
11-27-2010, 10:22 PM
so its my intake that should be worked on?????? will an ls6 suffice or should i go bigger????
crazyelf
11-28-2010, 05:01 PM
Ls6 intake, p&p tb and a tune will work fine for you. If you don't hit 11.9x or better after that I will kick myself in the dick.
