11 Second Club - First time at the Track with my New Motor...11.94@122.7
soundengineer
11-20-2010, 10:13 PM
Took My 408 to the track today...
First time out on my New Motor...
Just under 1500miles on the new motor
3800lb race weight..Full interior, with AC, Daily Driver, T56, Stock 3.42 rear gear 10bolt
On 245/50/16 tires today
1/4 Mile
11.94@122.7
1.9 60ft
and yes... I need a Rearend, a taller gear, and Slicks...and I will be DEEP into the 10's on Motor...
planning on putting in a 4l80e as well...
and also planning on a 300 shot of nitrous sometime in 2011
Was that with drag radials?
soundengineer
11-21-2010, 02:48 PM
No...
I should have borrowed some and tried to break something....but I didnt...
MikeG
11-21-2010, 08:45 PM
It's fun driving on glass isn't it? LOL
My car ran a 12.6 @ 116 w/ a 2.39 60' on street tires last time out. Just goes to show ya what a difference traction makes.
soundengineer
11-21-2010, 08:50 PM
once I get going.. my suspension kicks in and I dont have any issues...
its just the initial start that is the issue...
No...
Im impressed by that 60ft time, especially with the heavy iron block up front.
soundengineer
11-21-2010, 11:34 PM
the car is going to get a diet...I still daily drive it...so I'm not gutting it...but I will take out quite a bit of stuff to be ready for next year
CAMNXSS
11-22-2010, 12:37 PM
So are you spinning that much after you start, like half way through 1st gear? Reason I ask this is because sometimes it is easier to make the car bog on it self to keep the initial shock of torque off of the tires. Example for me I slipped the clutch from around 2000rpm and it bogs really hard and falls on its face around 10mph, but at the same time I can kept first gear floored and it doesnt give the tires enough shock to spin, kind of like a easy way to roll the throttle to keep form spinning. I netted a 1.9x 60ft as well with this approach, and still 12.10's with 120-121 mph. Just good ideas for a street run or if you are on shitty street tires or 555rs.
soundengineer
11-26-2010, 07:36 PM
it was breaking them free at the top of 1st gear....
I had to short shift 1st to keep from just blowing off the tires.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
