steveman0018
11-20-2010, 10:24 PM
So i had some extra money left over and decided to beef up the horns on the car. Living near the philly area you constantly get cut off and lets admit, the stocks horns just dont do it. So I picked up a set of the Hornblaster Shocker XLs. Comes with 4 horns, tank, compressor, all lines, cables, solenoid, and fittings. Here are some pics of the install plus a short video at the end. My overall goal for this install was to go stealth as you wont know i have the horns until i blast them. A lot of ppl mount them underneath there car and you can clearly see them.
First let me say that the Impy has very limited room to install these things. This install was by far the most difficult, espcially trying to get the airline to the horns from the trunk. These horns can be installed anywhere as they are weatherproof.. I found a good spot behind the lower grill as there was plenty of room to mount three of the 4 horns. I had to customize the splash car holder to fit the third horn in place. The 4th horn is mounted downwards are its on 12 inches long compared to the 14, 16, and 19 inch horns. mounted in this picture.
http://lcnsoldiers.net/horns/IMG_0875.JPG
This is what it looks like with the grill on. Barely can tell i have them there.
http://lcnsoldiers.net/horns/IMG_0878.JPG
Each horn is fed by this electric solenoid that sends the air to the horns when you push the button to open it. I mounted this in the upper grill area as this has to be close to the horns. Again it is powered from the battery to a switch then to the solenoid.
http://lcnsoldiers.net/horns/IMG_0880.JPG
I installed a pressure gauge and switch to monitor the pressure in the tank as well as turn it on and off whenever i wanted. The horns work best when the tank is filled to 150psi..
http://lcnsoldiers.net/horns/IMG_0885.JPG
Next i installed a switch i picked up at radioshack by the glovebox. This switch controls the solenoid which makes them blast. You can bypass this by hooking it up to your horn but i didnt want to fail inspection plus i would love to see the techs face when he scares the entire bay with it.
http://lcnsoldiers.net/horns/IMG_0886.JPG
In the next pic below is the tank, compressor, and pressure switch. I made up some cheap box to mount these. The tank is a 2 gallon tank and comes with 6 ports to hook up anything you want. They sell the attachments to fill up your tires with it. Its mounted behind my sub so its hidden when opening the trunk.
http://lcnsoldiers.net/horns/IMG_0888.JPG
Lastly this is from the trunk and you can just see some of the tank with the airline plugging into it that goes up to the horns..
http://lcnsoldiers.net/horns/IMG_0889.JPG
To sum it, it wasnt a easy install and took me 3 long days to do everything but once your done, man this thing gives your car some balls, I have made ppl jump out of there shoes at the bus stop and surprising got to use it on my first cutoff and man did that person get out of the way.
Here is a video of the stock horn compared to the hornblasters shocker xl. Listen to the echo. The camera doesnt do the justice on how loud these things are.
http://www.youtube.com/watch?v=anngQ4fpfLo
