PRC 215s vs PRC LS6 stage 1 Heads
How would these two compare to one another? I'd be running a MS4 cam with an LS6 intake for now but will be going to a FAST later on.
Thanks
Thanks
LS1Tech Premium Sponsor
The Stage 1 LS6 head is a great head on a budget, while the PRC 215 is the top of the line in terms of aftermarket casting quality & technology. It is built off a completely new casting with different port designs, valve angles & thicker deck surfaces. The 215s also have a completely cnc cut combustion chamber. The PRC 215s will allow you much higher compression, horsepower & torque while still being bolt on friendly even with stock rocker arms!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
