02 extensions
dont know if you've looked into it, but what i did was repin my pcm. took about 15 min and i was free. you swap the pins for your front and rear 02s then delete your rears. what you're doing pretty much is using the rear o2 harness as the front cause its longer. worked fine for me and i know i'm not the only one. i dont remember the pins to swap but with a quick search or if you have a repair manual with wire diagrams you can find it.
24" are way too long, go with 12", WS6store sells them if you want to buy them.
I swapped pins and it worked like a charm and took about 15 min once I knew what to look for. Easy way to save $
