Stock speakers blown and suck, Looking for cheap factory speaker replacements....
My car: 1999 TA with monsoon.
Basically my 11 year old factory speakers have seen better days. Just looking for some CHEAP replacement. Again I am not looking for the BEST sound. Just looking for a decent upgrade at a cheap price.
Here are some replacements I found:
http://www.sonicelectronix.com/item_...+KFC-P708.html
Would these work in the front door and rear seats? I was thinking about just unplugging the speakers that are in the hatch area and not replacing them.
Any help is appriciated.
Kfc-p708
I'm glad I checked over this section before posting a question identical to yours.
I checked with Crutchfield and they said the KFC-P708 is a drop in replacement for the stock Monsoon speakers and at $69.00 a good deal.
Like the OP, I'm just looking for an inexpensive replacement for the stock speakers. Anything cheaper/better than the Kenwood speakers, and/or how do the Kenwood speakers sound?
Ungrounded Moderator
Nothing is "plug and play" for the Monsoon system. At the very least you will have to cut the factory connector off and splice it to the replacement speaker to be able to plug into the factory harness.
Those components will work in the doors of a Firebird Monsoon system. They won't work in Camaro doors or the sail panels of either model. Monsoon sail panel speakers are subs and only get low frequency signal from the amp. You should read the Monsoon FAQ sticky at the top of the section for more information. Then look at replacement speaker packages from Kee Audio or SparksAI (both are sponsors here).
