Any Drawbacks to Sub-frame Connectors
I realize the benefits to adding SFCs to a vehicle; my main goal is to tighten up my '02 while it is still relatively new, and to hopefully avoid the rattle trap syndrome that plagued my 94. But are there any long term issues to deal with? Since the SFCs prevent some flex in the 'middle' of the chassis, the forces responsible for the twisting must be transfered elsewhere, right? Do you wind up subjecting other areas of the body/car to stresses not intended in the car's design? I just don't want to cure one problem but at the same time cause others.
Thanks for the help!
Bryan
Bryan
I don't have too much(or any, for that matter) experience with welding. How hard is it to weld in SFC's? Also, can anyone estimate what a shop might charge to do it? Is there any cutting involved?
I had a 69 Nova with a lot of suspension work done, and I had SFC's welded in. But you had to remove the back seat and carpeting, and actually cut into the floor. That was a bit costly, but well worth it. I assume there is much less cutting, if any at all with the F-bods.
Thanks for any help.
It's not mine! woo hoo!
There is no cutting. Just take it to a frame shop.
The only draw backs I know of would be less ground clearance (not all have this problem), and the extra weight. If you're worried about transfered flex, a strut brace for the front would help. So would a cage too
extra weight, slightly reduced ground clearance, and dimples in the rear quarter panels from tearing up the corners- this may or may not be from a more rigid chasis.
Originally Posted by P Mack
Seems to me all the flex you would ever need is in the suspension. No need for flex in the chassis.
i bought mine from a guy on ebay. they are the same as the global west, only 1/8" smaller in diameter (but 1/8" bigger than BMR SFC's) and they are over $100+ cheaper. made out of the exact same compounds as well.
dimples in the rear quarter panel? i've never heard of that. it must be a problem definetely not associated with SFC's.
if you have t-tops, over time, with more body flexing your chassis will bend, and thus, the tops won't fit on nearly as well, and you car will be much more prone to having leaky t-tops.
drawbacks - there are none really. your car will be a little bit stiffer ride, but i wouldn't really consider that a drawback unless you are looking for a cadillac ride
I have Spohn SFC on my 02 SS. As far as ground clearence goes, you can't even see them from the side. They are tucked behind the lip on the rocker panel. See pics:
http://community.webshots.com/user/sscamaro02
i dont have access to a welder either...would just bolting them on be as good as welding?? i have thoselittle dinky dimples in my 1/4s with 24,000 and change on the odemeter...i was thinking on gettin the SLP bolt on ones..also is the hotchkis any good...and ordering the bilstein shocks all at once...finally...AWESOME lookin car SS Camaro02 i wish mine was as clean
